Hello ,
I am using the "NRF52_MBED_TimerInterrupt.h" library for interrupts on my Arduino Nano BLE.
How can I change the clock frequency? It seems it is preset to 1Mhz, but I would like to increase it to 16MHz. I tried to change the PRSCALER with:
void initTimer4()
NRF_TIMER4->PRESCALER = 0;
But it didnt work.
Here is my Code:
#if !( ARDUINO_ARCH_NRF52840 && TARGET_NAME == ARDUINO_NANO33BLE )
#error This code is designed to run on nRF52-based Nano-33-BLE boards using mbed-RTOS platform! Please check your Tools->Board setting.
#endif
#define TIMER_INTERRUPT_DEBUG 1
#define _TIMERINTERRUPT_LOGLEVEL_ 3
#include "NRF52_MBED_TimerInterrupt.h"
#include "hw_config.h"
#define TIMER0_INTERVAL_US 1000 //1000
volatile uint32_t Timer0Count = 0;
void printResult(uint32_t currTime)
Serial.print(F("Time = "));
Serial.print(currTime);
Serial.print(F(", Timer0Count = "));
Serial.println(Timer0Count);
void TimerHandler0()
static bool toggle0 = false;
// Flag for checking to be sure ISR is working as SErial.print is not OK here in ISR
Timer0Count++;
//timer interrupt toggles pin LED_BUILTIN
digitalWrite(CNK_FREQ_OUTPUT, toggle0);
toggle0 = !toggle0;
void initTimer4()
NRF52_MBED_Timer ITimer0(NRF_TIMER_4);
pinMode(CNK_FREQ_OUTPUT, OUTPUT);
initTimer4();
while (!Serial && millis() < 5000);
delay(100);
Serial.print(F("\nStarting Argument_None on "));
Serial.println(BOARD_NAME);
Serial.println(NRF52_MBED_TIMER_INTERRUPT_VERSION);
if (ITimer0.attachInterruptInterval(TIMER0_INTERVAL_US, TimerHandler0))
Serial.print(F("Starting ITimer0 OK, millis() = "));
Serial.println(millis());
Serial.println(F("Can't set ITimer0. Select another freq. or timer"));
#define CHECK_INTERVAL_MS 999L
static uint32_t lastTime = 0;
static uint32_t currTime;
currTime = millis();
if (currTime - lastTime > CHECK_INTERVAL_MS)
printResult(currTime);
lastTime = currTime;
Thanks
