Using Interrupts with second input
I am struggling to use an interrupt with a second input using the &&, asfollows;
  const byte interruptPin = 3;
  const byte alarmPin = 9;
  pinMode(3, INPUT);
  pinMode(9, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), trigSMS, CHANGE);
if(flag)
    int val3 = digitalRead(alarmPin);
    int val = digitalRead(interruptPin);
    if(val==LOW && val3=LOW);
the if(val==LOW && val3=LOW); does not work, is there a workaround ?
Dan
dannyrfish:
Use the correct syntax?
Get rid of the trailing semicolon?
Add some controlled statements enclosed in curly braces?
Do you mean:
if(val==LOW && val3==LOW)
Paul
