Complete newby here. I'm having a problem getting my code to respond in the way that I expect it. I imagine it probably has to do with my variable use.
What I'm trying to accomplish:
I'm using the IR Remote and LiquidCrystal libraries, basically using the tutorial's code with a few modifications. I'm trying to build a simple reader that will read a variety of IR codes from remotes. I need to be able to take it to a location and read the response from dozens of remotes in different locations. Because of that, want my 1602 LCD to display the code so that I can make note of it for later. I plan to use the codes to create an IR blaster button box that will turn on all of my devices at once (multiple projectors and TVs, multiple manufacturers).
My questions/problems:
Question #1: will this even work to get the codes that I can create a IR transmitter?
Question #2: The Serial Monitor responds fine (formatted the way I want and everything). The LCD simply returns "0". So I know that it is looping properly, but is somehow not interpreting the data. My gut says that it's in the variable value "results" somewhere, but I really don't know. How can I get the LCD to give me a meaningful reading of my remote's code?
Question #3: Is there a way to store the inputs to retrieve later? For instance, if I go around and gather all of my remotes and get all of their codes, is there any way to download the data when I get back to my computer?
Here is my code:
#include <IRremote.h>
#include <LiquidCrystal.h>
int IR_RECEIVE_PIN = 7; // Receive on pin 11
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
decode_results results;
lcd.begin(16,2);
lcd.print("New Line");
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK); // Start the receiver, enable feedback LED, take LED feedback pin from the internal boards definition
if (IrReceiver.decode()) {
IrReceiver.printIRResultShort(&Serial);
lcd.clear();
lcd.print(results.value, HEX);
IrReceiver.resume(); // Continue receiving
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your pro…
It will help you get the very best out of the forum in the future.
Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
Always list the version of the IDE you are using and the board version if applicable.
Use quote or add error messages as an attachment NOT a picture.
