Using IR sensor for lock and button for Unlock
Hello guyz can you help me how to code
IR sensor controlling servo to stay on 90 degrees and after that when i press button it goes to 0 degrees
Most examples found use Infrared Remote control. This one on Youtube may be useful:
How to Control Servo Motor and IR sensor Module Using Arduino Uno R3 || Servo Motor || IR Sensor || - YouTube
Hello greedisland23
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
#include <Servo.h>
Servo tap_servo;
int sensor_pin = 4;
int tap_servo_pin = 5;
int touch_sensor = 6;
int val;
int val2;
void setup(){
pinMode(sensor_pin, INPUT);
tap_servo.attach(tap_servo_pin);
val = digitalRead(sensor_pin);
val2 = digitalRead(touch_sensor);
if (val == 1 && val2 == 0)
tap_servo.write(90);
while (val == 1 && val2 == 1)
tap_servo.write(0);
this my code i want for my servo
thanks for helping us :blush:
Hello
Nice sketch.
And the question is?
How i overlap my sensor when it is equal to 1 that my servo is in 90 degrees then when i touch the touchsensor it will go back the servo to 0 degrees
Hello
The IDE provides an example called State change detection
You may use this example to control the servo correctly.
