Using IR sensor remote to control DC and Servo motor
I am using a Robojax module of servo and DC motor to control both of them through the same code from 1 remote with IR sensor. I am facing a challenge in controlling both through same and i feel the issue is with my coding. I am able to use the servo motor with this code but DC motor is not working, the program is compiling without error but motor action is still not getting done.
I am attaching the code below. Please review and help:
The code was not attached.
Please post your full sketch. If possible, you should always post code directly in the forum thread as text using code tags (</> button on the toolbar). This will make it easy for anyone to look at it, which will increase the likelihood of you getting help. If the sketch is longer than the forum will allow then it's OK to add it as an attachment. After clicking the "Reply" button, you will see an "Attachments and other settings" link.
Please always do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
