Hi all,
Background of the project:
I want to control some lego power function devices by arduino via infrared, but I want to replace both, sender and receiver, with arduino and custom protocol to allow more accurate steering and to have more outputs available.
For better re-usability I thought of creating a receiver library which is doing the protocol handling, etc. but is implementing the library irRemote for doing the IR part.
But here comes my problem, which I do not understand: If i call irRemote from another library, i get only garbage as result from irRemote. If I call the same code from the ino the results are fine.
So, hopefully somebody can explain me where my problem is:
code which is working (using irRemote directly from ino)
ino file
#include "Arduino.h"
#include <IRremote.h>
const int RECV_PIN = A5;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
irrecv.blink13(true);
Serial.println ("starting direct sketch");
if (irrecv.decode(&results)) {
if (results.decode_type == NEC) {
Serial.print("NEC: ");
} else if (results.decode_type == SONY) {
Serial.print("SONY: ");
} else if (results.decode_type == RC5) {
Serial.print("RC5: ");
} else if (results.decode_type == RC6) {
Serial.print("RC6: ");
} else if (results.decode_type == UNKNOWN) {
Serial.print("UNKNOWN: ");
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
Here I always get the following output if I press
NEC: FFA25D
Now comes my problem:
code which is faulty using irRemote from other library
ino file
#include "ReceiverLibTest.h"
//The setup function is called once at startup of the sketch
ReceiverLibTest irReceiver;
// Add your initialization code here
Serial.println("Starting lib sketch");
// The loop function is called in an endless loop
irReceiver.processData();
library cpp
// Do not remove the include below
#include "IRremote.h"
#define IR_RECEIVE_PIN A5
IRrecv irrecv(IR_RECEIVE_PIN);
ReceiverLibTest::ReceiverLibTest()
// instanciate the infrared library on given pin
// start the IR Receiver
void ReceiverLibTest::processData()
Here, if i press the standby button on my remote again, i allways get random values:
UNKNOWN: E9E70E8D
UNKNOWN: CF51C16E
UNKNOWN: E1886D7F
UNKNOWN: 4BCF0C40
So, what is the problem here? Can anyone explain this behavior?
Thanks, butch
