i have used jeelib in the code i have been doing..i need some help whether i have successfully used jeelib or not...thanks
#include <VirtualWire.h>
#include <JeeLib.h>
#include <Ports.h>
ISR(WDT_vect) { Sleepy::watchdogEvent(); }
int dig= 8;
int val = 0;
int digib=4;
int bat= 0;
int j=0;
pinMode(dig,OUTPUT);
pinMode(digib,OUTPUT);
Serial.println("setup");
Serial.println("RANDOM");
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2400); // Bits per sec
vw_set_tx_pin(7);
delay(200);
if (j%11==0){
digitalWrite(dig,LOW);
digitalWrite(dig,HIGH);
val= analogRead(A3);
if(val>1000)
const char *msg2 =("ok");
vw_send((uint8_t *)msg2, strlen(msg2));
vw_wait_tx();
for(byte i=0; i<30; ++i)
Sleepy::loseSomeTime(60000);
Serial.print(" fail ");
const char *msg = "FL";
digitalWrite(13, true); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx();
delay(200);
digitalWrite(digib,HIGH);
delay(200);
bat=analogRead(A2);
if(bat>1000)
const char *str = " ok,";
vw_send((uint8_t *)str, strlen(str));
//Serial.print(strlen(str)); // Debug check
Serial.print(" OK , ");
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(digib,LOW);
const char *str = "cut,";
Serial.print(" cut ");
delay(200);
j++;
