Hello all,
I'm fairly new to libraries but I think it would help clean up my code and make programming a bunch of different arduinos a lot easier.
The current problem I'm having is trying to get the Joystick library to function within a library that will hopefully hold all of my joystick functions.
Here's the error I get:
Joystick[i_joy].setButton(i_button, 1);
src\myLib\myJoy.cpp:33:13: error: no match for 'operator[]' (operand types are 'Joystick_' and 'int')
Compiling .pio\build\due\FrameworkArduino\Reset.cpp.o
Here's a very shortened version of my code with trying to use libraries
Main.cpp
#include <Arduino.h>
#include <Joystick.h>
#define JOYSTICK_COUNT 1
#include "myLib\myJoy.h"
myJoy Joy;
Joystick_ Joystick[JOYSTICK_COUNT] = {
Joystick_(0x04, JOYSTICK_TYPE_JOYSTICK, //joystick address, joystick type (JOYSTICK_TYPE_JOYSTICK, JOYSTICK_TYPE_GAMEPAD, or JOYSTICK_TYPE_MULTI_AXIS)
25, 2, // button count, hat switch count
true, true, false, // X, Y, and Z Axis
true, true, false, // Rx, Ry, and Rz
false, false, // rudder and throttle
false, false, false) // accelerator, brake, and steering
*-------------------------------- GLOBAL CONFIGURATION SECTION ---------------------------------------
unsigned int delay_loop = 50; //[ms] time to delay at the end of Arduino Loop function.
*-------------------------------- ARDUINO PIN ASSIGNMENT SECTION ---------------------------------------
unsigned int Cage_Uncage_Switch = 52;
*-------------------------------- CONTROLLER BUTTON ASSIGNMENT SECTION---------------------------------------
int Cage_Uncage_Button = 0;
*-------------------------------- FORWARD FUNCTION DECLARATION SECTION ----------------------
void Right_Throttle_Side_Panel();
void Cage_Uncage_Switch_Interrupt();
volatile bool Cage_Uncage_Switch_Interrupt_Active = false;
void Button_hold_HOTAS(int i_joy, unsigned int i_switch, int i_button); //for HOTAS where multiple buttons on throttle may be toggled, removes while loop
*-------------------------------- ARDUINO PRIMARY FUNCTIONS ----------------------
Joy.initialize();
pinMode(Cage_Uncage_Switch, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(Cage_Uncage_Switch), Cage_Uncage_Switch_Interrupt, CHANGE);
delay(delay_loop);
*-------------------------------- INTERRUPT AND SWITCH MONITORING SECTION ----------------------
void Cage_Uncage_Switch_Interrupt(){
Cage_Uncage_Switch_Interrupt_Active = true;
void Right_Throttle_Side_Panel(){
if(Cage_Uncage_Switch_Interrupt_Active == true){
Joy.Button_hold_HOTAS(0, Cage_Uncage_Switch, Cage_Uncage_Button);
myJoy.h
myJoy.h - library to handle Joystick controls
#ifndef myJoy_h
#define myJoy_h
#include "Arduino.h"
class Joystick;
class myJoy
public:
myJoy();
void initialize();
//Joystick functions
//tracker variables
long pin_debounce_timers[54] = {};
bool pin_last[54] = {};
//delays
unsigned int delay_button_press = 50;
unsigned int delay_debounce = 100;
private:
#endif
myJoy.cpp
myJoy.cpp - library to handle Joystick controls
Joystick_ Joystick;
myJoy::myJoy(){
void myJoy::initialize(){
for (int i = 0; i < 54; i++)
pin_debounce_timers[i] = millis();
pin_last[i] = false;
void myJoy::Button_hold_HOTAS(int i_joy, unsigned int i_switch, int i_button){
if (digitalRead(i_switch) == LOW && pin_last[i_switch] == false && (millis() - pin_debounce_timers[i_switch] > delay_debounce))
pin_last[i_switch] = true;
pin_debounce_timers[i_switch] = millis();
else if (digitalRead(i_switch) == HIGH && pin_last[i_switch] == true && (millis() - pin_debounce_timers[i_switch] > delay_debounce))
Joystick[i_joy].setButton(i_button, 0);
pin_last[i_switch] = false;
