Using joystick to interrupt
Hello,
I’m trying to use sun founder joystick module to create interrupt and read it from my phone. I don’t need X-Y axis of the joystick so I didn’t include them on the code, I’m only using the push feature which is connected from joystick to D2 on the PCB. I can not read anything when I’m pushing the button, not on my phone neither on the serial monitor. When I create short circuit (by touching the pins) however I can read an output can someone help?
// Inspired by http://dmitry.gr/index.php?r=05.Projects&proj=11.%20Bluetooth%20LE%20fakery
#include "SPI.h"  // SPI in Arduino Uno/Nano: MOSI pin 11, MISO pin 12, SCK pin 13
#define PIN_CE  8 // chip enable 10 --> 9
#define PIN_CSN 9   // chip select (for SPI)
// The MAC address of BLE advertizer -- just make one up
#define MY_MAC_0  0x11
#define MY_MAC_1  0x22
#define MY_MAC_2  0x33
#define MY_MAC_3  0x44
#define MY_MAC_4  0x55
#define MY_MAC_5  0x66
int buttonPin = 2;     // the number of the pushbutton pin
int ledPin =  5;      // the number of the LED pin
int count = 0;
// variables will change:
volatile int buttonState = 0;         // variable for reading the pushbutton status
uint8_t buf[32];
static const uint8_t chRf[] = {2, 26, 80};
static const uint8_t chLe[] = {37, 38, 39};
uint8_t ch = 0;  // RF channel for frequency hopping
void btLeCrc(const uint8_t* data, uint8_t len, uint8_t* dst) {
  // implementing CRC with LFSR
  uint8_t v, t, d;
  while (len--) {
    d = *data++;
    for (v = 0; v < 8; v++, d >>= 1) {
      t = dst[0] >> 7;
      dst[0] <<= 1;
      if (dst[1] & 0x80) dst[0] |= 1;
      dst[1] <<= 1;
      if (dst[2] & 0x80) dst[1] |= 1;
      dst[2] <<= 1;
      if (t != (d & 1)) {
        dst[2] ^= 0x5B;
        dst[1] ^= 0x06;
uint8_t  swapbits(uint8_t a) {
  // reverse the bit order in a single byte
  uint8_t v = 0;
  if (a & 0x80) v |= 0x01;
  if (a & 0x40) v |= 0x02;
  if (a & 0x20) v |= 0x04;
  if (a & 0x10) v |= 0x08;
  if (a & 0x08) v |= 0x10;
  if (a & 0x04) v |= 0x20;
  if (a & 0x02) v |= 0x40;
  if (a & 0x01) v |= 0x80;
  return v;
void btLeWhiten(uint8_t* data, uint8_t len, uint8_t whitenCoeff) {
  // Implementing whitening with LFSR
  uint8_t  m;
  while (len--) {
    for (m = 1; m; m <<= 1) {
      if (whitenCoeff & 0x80) {
        whitenCoeff ^= 0x11;
        (*data) ^= m;
      whitenCoeff <<= 1;
    data++;
static inline uint8_t btLeWhitenStart(uint8_t chan) {
  //the value we actually use is what BT'd use left shifted one...makes our life easier
  return swapbits(chan) | 2;
void btLePacketEncode(uint8_t* packet, uint8_t len, uint8_t chan) {
  // Assemble the packet to be transmitted
  // Length is of packet, including crc. pre-populate crc in packet with initial crc value!
  uint8_t i, dataLen = len - 3;
  btLeCrc(packet, dataLen, packet + dataLen);
  for (i = 0; i < 3; i++, dataLen++)
    packet[dataLen] = swapbits(packet[dataLen]);
  btLeWhiten(packet, len, btLeWhitenStart(chan));
  for (i = 0; i < len; i++)
    packet[i] = swapbits(packet[i]); // the byte order of the packet should be reversed as well
uint8_t spi_byte(uint8_t byte) {
  // using Arduino's SPI library; clock out one byte
  SPI.transfer(byte);
  return byte;
void nrf_cmd(uint8_t cmd, uint8_t data) {
  // Write to nRF24's register
  digitalWrite(PIN_CSN, LOW);
  spi_byte(cmd);
  spi_byte(data);
  digitalWrite(PIN_CSN, HIGH);
void nrf_simplebyte(uint8_t cmd) {
  // transfer only one byte
  spi_byte(cmd);
void nrf_manybytes(uint8_t* data, uint8_t len) {
  // transfer several bytes in a row
  do {
    spi_byte(*data++);
  } while (--len);
  pinMode(PIN_CSN, OUTPUT);
  pinMode(PIN_CE, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(PIN_CE, LOW);
  Serial.println("Start LE advertizing");
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // Attach an interrupt to the ISR vector
  attachInterrupt(0, pin_ISR, CHANGE);
  // Now initialize nRF24L01+, setting general parameters
  nrf_cmd(0x20, 0x12);  //on, no crc, int on RX/TX done
  nrf_cmd(0x21, 0x00);  //no auto-acknowledge
  nrf_cmd(0x22, 0x00);  //no RX
  nrf_cmd(0x23, 0x02);  //4-byte address
  nrf_cmd(0x24, 0x00);  //no auto-retransmit
  nrf_cmd(0x26, 0x06);  //1MBps at 0dBm
  nrf_cmd(0x27, 0x3E);  //clear various flags
  nrf_cmd(0x3C, 0x00);  //no dynamic payloads
  nrf_cmd(0x3D, 0x00);  //no features
  nrf_cmd(0x31, 32);          //always RX 32 bytes
  nrf_cmd(0x22, 0x01);  //RX on pipe 0
  // Set access addresses (TX address in nRF24L01) to BLE advertising 0x8E89BED6
  // Remember that both bit and byte orders are reversed for BLE packet format
  buf[0] = 0x30;
  buf[1] = swapbits(0x8E);
  buf[2] = swapbits(0x89);
  buf[3] = swapbits(0xBE);
  buf[4] = swapbits(0xD6);
  nrf_manybytes(buf, 5);
  buf[0] = 0x2A;    // set RX address in nRF24L01, doesn't matter because RX is ignored in this case
void loop(){delay(1000);}
void loop2() {
  // Channel hopping
  for (ch = 0; ch < sizeof(chRf); ch++)
    uint8_t i, L = 0;
    buf[L++] = 0x42;  //PDU type, given address is random; 0x42 for Android and 0x40 for iPhone
    buf[L++] = 16 + 5; // length of payload
    buf[L++] = MY_MAC_0;
    buf[L++] = MY_MAC_1;
    buf[L++] = MY_MAC_2;
    buf[L++] = MY_MAC_3;
    buf[L++] = MY_MAC_4;
    buf[L++] = MY_MAC_5;
    buf[L++] = 2;   //flags (LE-only, general discoverable mode)
    buf[L++] = 0x01;
    buf[L++] = 0x06;
    buf[L++] = 6;   // length of the name, including type byte
    buf[L++] = 0x08;
    buf[L++] = 'n';
    buf[L++] = 'R';
    buf[L++] = 'F';
    buf[L++] = '2';
    buf[L++] = '4';
    buf[L++] = 4;   // length of custom data, including type byte
    buf[L++] = 0xff;
    buf[L++] = 0x01;
    buf[L++] = 0x02;
    buf[L++] = count;// some test data
    buf[L++] = 0x55;  //CRC start value: 0x555555
    buf[L++] = 0x55;
    buf[L++] = 0x55;
    nrf_cmd(0x25, chRf[ch]);
    nrf_cmd(0x27, 0x6E);  // Clear flags
    btLePacketEncode(buf, L, chLe[ch]);
    nrf_simplebyte(0xE2); //Clear RX Fifo
    nrf_simplebyte(0xE1); //Clear TX Fifo
    spi_byte(0xA0);
    for (i = 0 ; i < L ; i++) spi_byte(buf[i]);
    nrf_cmd(0x20, 0x12);  // TX on
    digitalWrite(PIN_CE, HIGH); // Enable Chip
    delay(2);        //
    digitalWrite(PIN_CE, LOW);   // (in preparation of switching to RX quickly)
  delay(200);    // Broadcasting interval
void pin_ISR() {
  buttonState = digitalRead(buttonPin);
  digitalWrite(ledPin, buttonState);
  Serial.println(count++);
  loop2();
  attachInterrupt(0, digitalPinToInterrupt(buttonPin), CHANGE);
You know, instead of having a loop() function which does nothing, it would be so much better to make this function check the pin repeatedly (thousands of times per second) and then you don’t need an interrupt.
void loop2() {
You should really give your functions names which describe what they do. Any time you have a number in a function name, you’re probably doing it wrong.
You should also know that any time you’re in an interrupt (on in a function called from an interrupt) then interrupts don’t work. Some libraries depend on interrupts, such as the Serial library. Do all this stuff in the main loop() function.
