From a relative newbie here, I’m trying to use temperature data from Open Weather to determine color of an RGB led with a NodeMCU ESP32); unfortunately, when trying to convert temperature data to an integer value to use in subsequent code to define RGB color, I keep getting this compiling error: 'tempDegC' was not declared in this scope
I'm very much a newbie, so perhaps I'm forgetting something obvious here. I did declare the tempDegC int variable in the setup. I append below my code (mostly from ESP32 HTTP GET with Arduino IDE (OpenWeatherMap.org and ThingSpeak) | Random Nerd Tutorials), and apologize for its messiness/the way I might have butchered the original excellent code. . .and the likely very basic nature of my question. Thank you in advance!
Code:
Rui Santos
Complete project details at Complete project details at https://RandomNerdTutorials.com/esp32-http-get-open-weather-map-thingspeak-arduino/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
#define PIN_RED 23 // GIOP23
#define PIN_GREEN 22 // GIOP22
#define PIN_BLUE 21 // GIOP21
const char* ssid = "hidden";
const char* password = "hidden";
// Your Domain name with URL path or IP address with path
String openWeatherMapApiKey = "hidden";
// Example:
//String openWeatherMapApiKey = " ";
// Replace with your country code and city
String city = "Phoenix";
String countryCode = "US";
// THE DEFAULT TIMER IS SET TO 10 SECONDS FOR TESTING PURPOSES
// For a final application, check the API call limits per hour/minute to avoid getting blocked/banned
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 10 seconds (10000)
unsigned long timerDelay = 10000;
String jsonBuffer;
int tempDegC;
WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println("Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.");
pinMode(PIN_RED, OUTPUT);
pinMode(PIN_GREEN, OUTPUT);
pinMode(PIN_BLUE, OUTPUT);
analogWrite(PIN_RED, 120);
analogWrite(PIN_GREEN, 60);
analogWrite(PIN_BLUE, 60);
// Send an HTTP GET request
if ((millis() - lastTime) > timerDelay) {
// Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey;
jsonBuffer = httpGETRequest(serverPath.c_str());
Serial.println(jsonBuffer);
JSONVar myObject = JSON.parse(jsonBuffer);
// JSON.typeof(jsonVar) can be used to get the type of the var
if (JSON.typeof(myObject) == "undefined") {
Serial.println("Parsing input failed!");
return;
Serial.print("JSON object = ");
Serial.println(myObject);
Serial.print("Temperature: ");
Serial.println(myObject["main"]["temp"]);
Serial.print("Pressure: ");
Serial.println(myObject["main"]["pressure"]);
Serial.print("Humidity: ");
Serial.println(myObject["main"]["humidity"]);
Serial.print("Wind Speed: ");
Serial.println(myObject["wind"]["speed"]);
tempDegC = int(myObject["main"]["temp"]);
else {
Serial.println("WiFi Disconnected");
lastTime = millis();
if (tempeDegC) > 273 {
analogWrite(PIN_RED, 20);
analogWrite(PIN_GREEN, 250);
analogWrite(PIN_BLUE, 0);
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
http.begin(client, serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
and here are the compiler error messages:
C:\Users\Desktop\Arduino \open_weather_api_test_if_then_sketch\open_weather_api_test_if_then_sketch.ino: In function 'void loop()':
open_weather_api_test_if_then_sketch:95:7: error: 'tempDegC' was not declared in this scope
C:\Users\Desktop\Arduino\open_weather_api_test_if_then_sketch\open_weather_api_test_if_then_sketch.ino:95:7: note: suggested alternative: 'tempnam'
tempnam
Multiple libraries were found for "WiFi.h"
Used: C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
