Using keypad.h to input decimals
I currently am using a method to input numbers like a keyboard, where hitting a key pushes the other keys back, and the clear button clears the last button pushed. How would I modify this code so I can put a decimal in? I’m having a hard time trying to figure out how to put a decimal point in an array, and how to make sure there is only 1 decimal point at a time.
float numberEntry(int numbercsr)
  long entry;
  lcd.setCursor(0,2);
  lcd.print("NUMBER ENTRY");
  lcd.setCursor(0,3);
  lcd.print("PRESS # TO CONFIRM");
  int counter[7] = {0,0,0,0,0,0,0}; //Array to hold numbers entered
  z = 0; //Used to determine how many numbers are currently being used
entryloop:
  lcd.setCursor(numbercsr, 1);
  lcd.cursor();
  delay(30); //To keep cursor blinking
  key = kp.getKey();
  // checks if key is pressed
  if(key != NO_KEY){
    x = key - '0'; //converts key pressed into an int
    if(x >= 0 && x<=9){
     lcd.setCursor(numbercsr,1);
     switch (z){
       case 0:
         counter[6]=x;
         lcd.print(x);
         z++;
       case 1:
         counter[5] = counter[6]; //Used to push old number back while placing the new number at the end
         counter[6] = x;
         for(i = 5; i < 7; i++)
          lcd.print(counter[i]);
         z++;
       case 2:
         counter[4] = counter[5];
         counter[6] = x;
         for(i = 4; i<7; i++)
         z++;
       case 3:
        counter[3] = counter[4];
        counter[6] = x;
         for(i = 3; i<7; i++)
         z++;
      case 4:
        counter[2] = counter[3];
        counter[6] = x;
         for(i = 2; i<7; i++){
         z++;
       case 5:
       counter[1] = counter[2];
       counter[6] = x;
         for(i = 1; i<7; i++)
         z++;
      case 6:
       counter[0] = counter[1];
       counter[6] = x;
         for(i = 0; i<7; i++)
         z++;
     case 7:
       counter[0] = counter[1]; //Will push the oldest number off the array to add the newest number at the end
       counter[6] = x;
    //Confirm the number
    if (key == '#'){
      lcd.noCursor();
      entry = (counter[0]*1000000) + (counter[1]*100000) + (counter[2]*10000) + (counter[3]*1000) + (counter[4]*100) + (counter[5]*10) + (counter[6]);
      lcd.setCursor(0,2);
      lcd.print("            "); //Clear the line to overlapping letters
      lcd.setCursor(0,2);
      lcd.print("NUMBER ACCEPTED");
      lcd.setCursor(0,3);
      lcd.print(" "); //Clear the line to avoid overlapping letters
      lcd.setCursor(0,3);
      lcd.print("PRESS S TO CONTINUE");
      return entry;
    //Leave the number menu
    if (key == '*'){
      lcd.clear();
      lcd.print("     Setup Mode");
      lcd.setCursor(0,2);
      lcd.print("RETURNING ZERO");
      lcd.setCursor(0,3);
      lcd.print("PRESS B TO RETURN");
      return 0;
    if(key == 'C'){
      lcd.print("       ");
      switch(z){
        case 7:
         counter[6] = counter[5]; //Deletes the newest key and pushes everything back to the right, to emulate a keyboard
         counter[5] = counter[4];
         counter[4] = counter[3];
         counter[3] = counter[2];
         counter[2] = counter[1];
         counter[1] = counter[0];
         counter[0] = 0;
         for(i = 1; i < 7; i++)
          lcd.print(counter[i]); //Prints remaining keys
         z--;
        case 6:
         counter[1] = 0;
         for(i = 2; i < 7; i++)
         z--;
        case 5:
         counter[2] = 0;
         for(i = 3; i < 7; i++)
         z--;
        case 4:
         counter[3] = 0;
         for(i = 4; i < 7; i++)
         z--;
        case 3:
         counter[4] = 0;
         z--;
        case 2:
         counter[5] = 0;
          lcd.print(counter[6]);
          z--;
        case 1:
          counter[6] = 0;
          z--;
        case 0:
          counter[6] = 0;
  lcd.noCursor();
  goto entryloop;
What range of numbers do you want to support and what key do you want to use for a decimal point?
Only a range of 3 numbers, and I want to use 'D' as the decimal point, as my other keys are already being used.
Why not just store the keys(chars) pressed into a char array and use atof()?
I do it by entering the digits directly into a floating point variable as follows
void entry()
 if (DP == 0)
{Entry = Entry * 10;
 Entry = Entry + Digit;
//Serial.println(Entry);
 if (DP > 0)
 Digit = Digit / pow(10,DP);
 //Serial.println(Entry, DP);
 DP = DP + 1;
Note when the decimal point is pressed DP is set to 1 only if it is 0.
Also DP will contain the number of decimal places +1
HazardsMind:
It was the easiest way to check if the key pressed was an actual number instead of writing a bunch of ORs.
