My final project goal is to use a 4x4 keypad to control a stepper motor and have each button correspond to a (as of yet undetermined) number of pulses. Additionally, I want a forward and reverse button.
Right now my code wont drive the motor, but the motor is responding with what seems to be a single pule. Its also responding to buttons I'm pressing but havent defined if statements for, so that is baffling.
Im new to programming so I appologize in advance for my ignorance.
In an effort to debug my approach I put together my stepper code using the standard button example and wired a single button, this worked without any issues.
My set up is a GeekDuino and RobotGeek button, with a NEMA 23 motor, a TB6600 driver and this keypad https://www.amazon.com/gp/product/B015M1CEIC/ref=od_aui_detailpages01?ie=UTF8&psc=1
Motor code that works no issue with simple button IMG 4094 - YouTube
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 13
; // the number of the pushbutton pin
//const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
int dirpin = 0;
int steppin = 1;
// initialize the LED pin as an output:
// pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
pinMode(dirpin, OUTPUT);
pinMode(steppin, OUTPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
int i;
digitalWrite(dirpin, LOW); // Set the direction.
for (i = 0; i<4000; i++) // Iterate for 4000 microsteps.
digitalWrite(steppin, LOW); // This LOW to HIGH change is what creates the
delayMicroseconds(450); // This delay time is close to top speed for this
digitalWrite(steppin, HIGH); // "Rising Edge" so the easydriver knows to when to step.
} // particular motor. Any faster the motor stalls.
digitalWrite(dirpin, HIGH); // Change direction.
for (i = 0; i<400; i++) // Iterate for 4000 microsteps
HERE IS THE CODE THAT I AM HAVING ISSUES WITH IMG 4093 - YouTube
#include <Key.h>
#include <Keypad.h>
int dirpin = 0;
int steppin = 1;
/* the tutorial code for 3x4 Matrix Keypad with Arduino is as
This code prints the key pressed on the keypad to the serial port*/
const byte Rows= 4; //number of rows on the keypad i.e. 4
const byte Cols= 4; //number of columns on the keypad i,e, 3
//we will definne the key map as on the key pad:
char keymap[Rows][Cols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
// a char array is defined as it can be seen on the above
//keypad connections to the arduino terminals is given as:
byte rPins[Rows]= {2,3,4,5}; //Rows 0 to 3
byte cPins[Cols]= {6,7,8,9}; //Columns 0 to 3
// command for library forkeypad
//initializes an instance of the Keypad class
Keypad kpd= Keypad(makeKeymap(keymap), rPins, cPins, Rows, Cols);
Serial.begin(9600); // initializing serail monitor
//If key is pressed, this key is stored in 'keypressed' variable
//If key is not equal to 'NO_KEY', then this key is printed out
char keypressed = kpd.getKey();
if (keypressed != NO_KEY)
Serial.println(keypressed);
if (keypressed =='1'){
int i;
for (i = 0; i<400; i++) // Iterate for 4000 microsteps.
Serial.println("hERE IS AM");
Serial.println("sECOND sAM");
