Using Landscape power supply
I have a 120 watt 12v landscape lighting power supply. It works perfectly, but when I hook it up to a buck converter to reduce 12 to 5v it always cooks (explodes) the regulator. Assumming too much current. Can this supply be used?
Are you sure that it is a DC power supply and not AC ?
Dang! I did not even know these were available in AC. Solved!
If your question has been answered to your satisfaction, please mark the thread as solved so that other members that wish to help will not waste their time opening the thread only to find that you no longer require assistance.
Look at the label on the power unit. The equal sign == tells DC, a horisontal snake figure tells AC...
