the mechanical pin into a slot would be one of the ways to go.
the stepper would be far more accurate than you can imagine.
the exposed gear has something over 80 teeth (guessing as I can see 20)
a stepper with 200 steps per rotation with a 8x micro-stepper will have 1,600 steps per rotation
times 80 teeth, the final rotary unit will have 128,000 steps per rotation.
using my rule of thumb that you have to be 4 times more accurate than your desired drive accuracy, we can divide that by 4 to get 64,000 steps per rotation.
swapping mm for steps, and using the circumference of the device, 64,000 mm
using the formula of pi times the diameter, we divide 64,000 by pi to get just over 2,000 cm carrying that out to English units, I come up with a accuracy of alignment of 1/4 mm if the turntable were only 66 feet in diameter.
I am sure my math went off the rails as I have not had coffee yet, but even if it was off by an order of magnitude, your table does not look like it is 6 feet in diameter. ( I am blaming the lack off coffee for the huge divide by two and not by 4 error)
alas, for a stepper, you trade power and precision for speed. I will not venture to guess how many hours it will take for one revolution. just joking it will take a fraction of an hour. 2/3 is a fraction, right ?
also, you can easily buy a optical interrupter that is far more common, far easier to use and also more accurate than you need. your old mouse had two as did almost every scanner or copier I ever took apart.
one emitter with a slit and one receiver at the end of a tube with a slit will offer a high degree of alignment.
you can use an encoder wheel connected to the existing table. print it on copy paper and use some sensors. or use a stepper with an encoder for feedback or the existing motor. putting it on the drive wheel will offer accuracy in the realm as listed above.
someone once posted a link to a logic problem something like X-Y formula... said that we respond to posts using the logic of someone who has eliminated workable solutions for unknown reasons and then we try to use the logic that is left. the lack of diameter of the rotary? )coffee done brewing.. had a couple sips)
if it were me and I was really into this hobby, I would look at a sign that rotated. the rotation would lock in the turntable to the rail in some fashion. the sign could spin or raise up out of the ground to indicate to the engineer that the alignment is ready and the track is aligned. For that a tiny servo, a solenoid, pretty much any mechanical device could be used.
if it were me, I would make my own stepper belt drive. 1mm accuracy end result with 1/4mm positioning accuracy. Assuming the rotary table were 18 inches across, that is 460 mm in circumference. a stepper with a 4:1 belt ratio and 200 steps per rotation would be 200x4 or 800 steps per rotation. using a half step driver, would jump that to 1,600 steps per rotation. pretty close to the 4:1 ratio I would want. speed would be good, power would be good. may go to 5:1 belt ratio.
I would still use an optical interrupter. if only for a home position.
one note here is that steppers are really only accurate to 1/2 step. you can get krazy microstepping numbers, but when you loose power the motor moves to the closest half step. tying to use a high value microstepping driver may have the effect loosing steps by cycling power. microstepping is great for smooth operation and I use them without reservation. just also use a home switch for accuracy.
lastly, you can use 3 interupters, one center, one left, one right, for extreme accuracy. lots more work, but using the 2 outter ones increases the accuracy by an order of magnitude.
rambleMode=LOW;
