#include <SevenSegment.h>
#define CLOCK 44 // Arduino digital 44 -> AY0438 clock
#define DATA 46 // Ardino digital 46 -> AY0438 data
#define LOAD 45 // Ardino digital 45 -> AY0438 load
SevenSegment screen(CLOCK, DATA, LOAD);
uint16_t counter = 0;
void setup(){
if i use arduino nano instead arduino mega, which pin for data, clock and load ?
i think to use clock = A4
but i don't know the other
can someone suggest me?
thanks
roberto
I think that you can use any pins. Just make sure that the pins chosen are the ones inserted into the pin defines.
Replace 44, 45, 46 with the pin numbers that you choose.
And, yes, it is perfectly fine to use the analog inputs (A0 - A5) as digital pins.
Note that A6 and A7 may NOT be used as digital pins.
