Thank you so much! I think that works. I can try to explain why I asked this.
I am reworking old code for a music drum sequencer device with alot of features, an oled display, 25 buttons, a lot of leds, an encoder and a switch, 20 Trigger outputs, 2 analog outputs, 2 analog inputs, midi output and midi input. I am not a pro programmer, but I try my best to do it better than my previous procedural version of the code which consisted of about 15 ino tabs in the arduino IDE in which there were many globally accessible variables defined.
Now I develop a Class Object for every different Feature. For example a User input Interface class which contains all code needed for this and of course the "DisplayInterfaceClass --> DCI.
When combining all these classes in the main deviceClass I had the problem that I needed to put all following code which needed access the these inside the deviceClass which would end up as a huge amount of code. So I thought how can I keep the structure but get access to the lcd, the leds etc from anywhere. First I tried to just make every member of the class Object I wanted to use everywhere as static, but that did not work with the LCD Object. Then while researching I stumbled upon the singleton class concept and I thought that might be the right thing for me.
For testing I just created a Class called PCI instead of DCI (Display Control Interface) because i had that one already.
Now it seems to work, I will have to change alot of code now, but I think now I can use the dci object anyhwere. I think I will do the same with the main Device Class.
I am actually not really sure of what the best concept is to bring all those elements together, I am just trying it out forever.
This is the code of you with my Inclusions.
DCI.h
#ifndef DCI_CLASS
#define DCI_CLASS
#include "DCI_constants.h"
* DISPLAY CONTROL INTERFACE
* The DCI Class contains all function to controll the LCD Display and the LEDs of the SEQ-V100 Sequencer.
#include "LCD.h"
LCD.h by David Mellis < Elco Jacobs < W.Earl from Adafruit -> you need to copy the Library from this repos (Firmware/Bibilotheken/LCD) to your Arduino IDEs libraries folder.
This is a custom modified (by me) Library to use the 16x2 Raystar OLED Display of the Sequencer
https://github.com/technobly/Adafruit_CharacterOLED/blob/master/Adafruit_CharacterOLED.h
It itself again was based on the LiquidCrystal Library
I followed this displayde to hook the display up.
https://learn.sparkfun.com/tutorials/oled-display-hookup-displayde/all
More Info about it in this repo under Features/OLED Display.
struct LedRuntime {
// LED On/Off States
boolean states[29];
// LED Blinking
uint8_t blinkStates[29];
unsigned long blinkLast;
unsigned int blinkInterval = 100; // in ms
uint8_t blinkCount;
// Update Flags
boolean updateFlag;
// Singleton Class
// See : https://forum.arduino.cc/t/using-lcd-class-object-as-static-member/916976/8
class DCI {
public:
// Strange singleton code
DCI(const DCI &) = delete; // I dont understand, but if it works...
DCI &operator=(const DCI &) = delete; // I dont understand, but if it works...
static DCI &getInstance();
// Properties
// LCD
LCD lcd;
// LEDS
LedRuntime led;
// Methods
void begin();
void run();
private:
DCI() : lcd(OLED_V2, A13, A12, A14, A8, A9, A10, A11) {}
// Properties
int8_t _ledMap[29];
// Methods
void _setupPins();
// LCD
void _initLCD();
void _setupCustomLCDCharacters();
// LED
void _initLED();
void _updateLeds();
void _clearStepLeds();
// Utilities
void _setupLedMaps();
extern DCI &display;
#endif
DCI.cpp
#include <Arduino.h>
#include "DCI.h"
* Strange singleton code
DCI & DCI::getInstance() {
static DCI instance;
instance.begin();
return instance;
* Public Methods
void DCI::begin() {
// Pin Setup
this->_setupPins();
// Hardware I/O Setup
this->_initLCD();
this->_initLED();
void DCI::run() {
// Process Led Runtime
this->_updateLeds();
* Private Methods
void DCI::_setupPins() {
// LED DRIVER OUTPUT
DDRD |= (1 << 7); // CLOCK OUTPUT
PORTD &= ~(1 << 7);
DDRF |= (1 << 7); // ENABLE OUTPUT
PORTF |= (1 << 7); // set high -> disabthis->led
DDRL |= (1 << 3); // DATA OUTPUT
PORTL &= ~(1 << 3);
// LCD
void DCI::_initLCD() {
//lcd = lcd;
// Note: LCD only clears character if printed with single quotes lcd.print(' ');
this->_setupCustomLCDCharacters();
this->lcd.home();
this->lcd.clear();
void DCI::_setupCustomLCDCharacters() {
// Setup Custom Characters for LCD
this->lcd.command(LCD_FUNCTIONSET | LCD_EUROPEAN_I);
// USER DEFINED SYMBOLS FOR LCD MENU
this->lcd.createChar(SYMBOL_LOOP, CHAR_CODE_LOOP);
this->lcd.createChar(SYMBOL_RECYCLE, CHAR_CODE_RECYCLE);
this->lcd.createChar(SYMBOL_PL, CHAR_CODE_PL);
this->lcd.createChar(SYMBOL_AY, CHAR_CODE_AY);
this->lcd.createChar(SYMBOL_PL2, CHAR_CODE_PL2);
this->lcd.createChar(SYMBOL_PLAY, CHAR_CODE_PLAY);
// LED
void DCI::_initLED() {
_setupLedMaps();
// Led States
for (int i = 0; i < 29; i++) {
this->led.states[i] = LED_OFF;
// Blink States
this->led.blinkStates[i] = LED_BLINK_OFF;
this->led.updateFlag = true;
_updateLeds();
// Show snake to check every step button this->led
for (int i = 0; i < 16; i++) {
this->led.states[i] = LED_ON;
if (i > 0) {
this->led.states[i-1] = LED_OFF;
_updateLeds();
delay(100);
_clearStepLeds();
_updateLeds();
void DCI::_updateLeds() {
* This method bit bangs out data to a multi-channel this->led driver chip.
// Update Blink count after blinkInterval
if ((millis() - this->led.blinkLast) > this->led.blinkInterval) {
this->led.blinkLast = millis();
if (this->led.blinkCount > 3) this->led.blinkCount = 0;
this->led.blinkCount++;
if(this->led.updateFlag) {
int8_t index;
PORTF &= ~(1 << 7); // enable LED DRIVER
for (uint8_t i = 0; i < 37; i++) {
if (i == 0) {
PORTL |= (1<<3);
// Shift out LED data
if (i > 0 && i < 30) {
// GET index in states array
index = this->_ledMap[i-1];
if (this->led.blinkStates[index] == LED_BLINK_SLOW && (this->led.blinkCount == 1 || this->led.blinkCount == 2) ) {
PORTL |= (1<<3);
} else
if (this->led.blinkStates[index] == LED_BLINK_FAST && (this->led.blinkCount == 1 || this->led.blinkCount == 3) ) {
PORTL |= (1<<3);
} else
if (this->led.states[index] && this->led.blinkStates[index] == LED_BLINK_OFF) {
PORTL |= (1<<3);
// Clock Pulse
PORTD |= (1 << 7);
PORTD &= ~(1 << 7);
PORTL &= ~(1 << 3);
PORTF |= (1 << 7); // disable LED DRIVER
this->led.updateFlag = false;
void DCI::_clearStepLeds() {
// Utilites
void DCI::_setupLedMaps() {
// index = channel of the Led Driver
// value = this->ledStates index for that output channel
// 16 Step Button Leds
this->_ledMap[16]=0;
this->_ledMap[15]=1;
this->_ledMap[14]=2;
this->_ledMap[13]=3;
this->_ledMap[12]=4;
this->_ledMap[10]=5;
this->_ledMap[9]=6;
this->_ledMap[8]=7;
this->_ledMap[2]=8;
this->_ledMap[11]=9;
this->_ledMap[17]=10;
this->_ledMap[0]=11;
this->_ledMap[1]=12;
this->_ledMap[3]=13;
this->_ledMap[4]=14;
this->_ledMap[5]=15;
// Other Buttons
this->_ledMap[7] = LED_BUTTON_PLAY; // PLAY
this->_ledMap[6] = LED_BUTTON_SHIFT; // SHIFT
this->_ledMap[18] = LED_BUTTON_A; // A
this->_ledMap[19] = LED_BUTTON_B; // B
this->_ledMap[20] = LED_BUTTON_C; // C
this->_ledMap[21] = LED_BUTTON_D; // D
this->_ledMap[22] = LED_BUTTON_E; // E
this->_ledMap[23] = LED_BUTTON_F; // F
this->_ledMap[24] = LED_SWITCH; // SWITCH
this->_ledMap[25] = LED_BAR_1; // BAR 1
this->_ledMap[26] = LED_BAR_2; // BAR 2
this->_ledMap[27] = LED_BAR_3; // BAR 3
this->_ledMap[28] = LED_BAR_4; // BAR 4
DCI &display {DCI::getInstance()};
software.ino
* This is the firmware for the Button Matrix and Encoder Controller
* of the SEQ-V100 Sequencer.
#include "DCI.h"
#include "seqV100.h"
// Sequencer
SeqV100 seqV100;
// Set Tempo Interrupt Service
ISR(TIMER3_OVF_vect) {
seqV100.tempoController.tempoClockInterrupt();
display.lcd.print("hallo");
// Init SeqV100 instance
seqV100.begin();
seqV100.run();
Thank you so much for your help!!! I am really running out of Energy, these programming knowledge things seem to have no end...
Do I have to set all of the singletons class / object methods to static ? It doesnt work if write static LCD lcd; in the Class definition
-Flub
