Using LDR and LM35 at the same time
Hi All,
I seem to be having a few problems, (and I took a 29 year break from electronics so I am rusty).
I have managed to interface my Arduino Duemilanove with an LDR and with a LM35 sensor, the problem is that I use the LM35 with 1.1v internal source and the LDR with 5v source to get the better results. Any ideas on how I can do both at the same time? (the LDR seems to have 100R - 47K resistance).
I tried to force the LDR to 1.1volts by a voltage divider 28R but it looks to be a logarithmic result, so I loose a lot of accuracy (tracking daylight).
My other thought was to use the 3.3v line as a reference connecting it to Aref? would this work?
TIA
Regards
Darren
AS the voltage reference is switchable in software then just switch in the right one before taking the reading.
That will work as well, how are you connecting it up. It should be LDR to ground and input with a pull up resistor.
You don't want to track the sun do you?
I have code for that :slight_smile:
http://www.mowcius.co.uk/suntrackercode.html
Mowcius
