Since Halloween is just around the corner, I was thinking about using an Arduino to create music reactive lights. How should I go about wiring this? The LED strip I’m using takes 5V of power, and the music sensor also takes 3.3-5V. Should I wire the battery straight to the LEDs, or to the Arduino?
You would have 3 wires connected to each supply lead, i.e. +5v and GND power Bank terminals.
The Arduino 5v pin goes to one of the +5v Bank wires.
NOTE: Do not connect an UNO or Pro Mini to the Bank when you upload your sketch to the Arduino from the PC.
