Using Libraries
In the instruction to import a library. First you copy the zip file to your hard drive. My problem is where is the zip file. Example: I need two files from the Arduino library. http://www.arduino.cc/en/Reference/Libraries The program names are Matrix and Sprite. I found the titles but where is the zip files?
Wherever you copied it to.
from that page: "The Matrix and Sprite libraries are no longer part of the core distribution.
So where did you found you needed those libraries?
The "Matrix" and "Sprite" (Wiring) libraries are still available here:- Matrix & Sprite Libraries The download link is near the top and toward the bottom of the page are links to the documentation on the 'Wiring' site.
Here is the procedure for installing a library from a zip file:
How to Install a Library (arduino.cc)
