Using LilyPad bootloader on 328p-au
HI there,
I am trying out Nick Gammons bootloader tutorial and using the lilypad setup at 8mhz. Would this bootloader support using analog pins 6 and 7. I am trying to read a voltage on pin 6 but am geting nothing back (i.e. 0). Is it the case that it simply is not supported?? There is the option to bootload the uno version but wonder is this the same outcome?
thanks for looking
Which bootloader you have installed does not affect whether or not some pins work. The bootloader just helps you upload new sketches to the ATmega328p using a USB-to-serial adapter.
