Hello,im using a line sensor for a project of mine the idea is that when the line sensor sensed the black line it will activate the will to go to the left then to the right
Idk a good code for it
Im using a arduino uno
A line sensor (IR sensor)
A DC motor with wheel connected to a l298n module
It isn't much clear, anyway if your project is a "line following robot" why don't you start googling it to find one of the dozens (hundreds..) of similar existing projects, together with the code?
You will want two line sensors. When both sense white, go straight. When left senses black, angle left. When right senses black, angle right.
You will want two motors and speed control of each motor for steering. To steer left, slow the left wheel (or increase the right). To steer right, slow the right wheel (or increase the left).
