I’ve been working (successfully) with the LiquidCrystal.h library, and I now want to incorporate it into a library of my own (a library that will include some custom characters beyond the normal ascii stuff).
I’m having a couple of problems building my new library because
- I’m not sure how to handle constructors that require parameters, and
- I don’t understand how the ‘begin’ method defined in the LiquidCrystal.h library seems to be defined with three parameters, but works happily with two. (is charsize = LCD_5x8DOTS a default for the 3rd parameter?)
I’ve attached my library files…
LCDvario.h
#ifndef LCDvario_h // These lines (together with the #endif at the end of the file) prevent
#define LCDvario_h // any problems occuring if this library should be included twice.
extern "C" {
#include <string.h>
#include <stdlib.h> // needed for 'free'
#include "WProgram.h" // needed for 'Serial'
#include <avr/pgmspace.h> // Needed for PROGMAN stuff
#include <ProgmemConst.h> // Global progmem constants
#include <Wire.h> // Needed for I2C comms.
#include <LiquidCrystal.h> // Drives the LCD screen
#include <inttypes.h>
class LCDvario
public:
LCDvario(uint8_t rs, uint8_t enable,uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3); // Constructor
//void begin();
void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS);// initialise stuff
private:
// Member variables
LiquidCrystal _lcd; // This would work if the constructor didn't require parameters
//LiquidCrystal _lcd(rs, enable, d0, d1, d2, d3);
//LiquidCrystal * _lcd;
//LiquidCrystal _lcd(uint8_t rs, uint8_t enable,uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3);
#endif
LCDvario.cpp
extern "C" {
#include <string.h>
#include <Wire.h>
#include <math.h> // needed for log functions
#include "LCDvario.h" // Header for this library
LCDvario::LCDvario(uint8_t rs,uint8_t enable,uint8_t d0,uint8_t d1,uint8_t d2,uint8_t d3)
//_lcd(rs,enable,d0,d1,d2,d3);
//_lcd=new LiquidCrystal(rs,enable,d0,d1,d2,d3);
_lcd._lcd(rs,enable,d0,d1,d2,d3);
//_lcd::_lcd(rs,enable,d0,d1,d2,d3);
//void LCDvario::begin()
// // initailise the LCD
// //_lcd.begin(16, 2);
void LCDvario::begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS)
_lcd.begin(cols, rows);
And the very basic sketch to test this
#include <Wire.h> // Library to control I2C comunications
#include <LiquidCrystal.h> // Controls access to the LCD display
#include <LCDvario.h> // LCD screen customised for vario use.
const int rs=8,en=9,d4=10,d5=11,d6=12,d7=13; // Pin definitions for LCD
LCDvario lcd(rs, en, d4, d5, d6, d7); // Display
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
As you can see from all the commented-out lines, I’ve several different methods of invoking the constructor, all of which give a slightly different error, but “no matching function for call to ‘LiquidCrystal::LiquidCrystal()’” seems to be the most frequent one.
Any help appreciated.
