Hello everyone. I have been a lurker for some time. I have frustrated myself quite enough with the current project I am on, and would be grateful for any guidance.
Here's a quick overview of the project: I am adding 10 LEDs, a 12v fan, and a 3 by 4 matrix keypad to my 3D printer. I want to start a print, go over and punch 3 keys on the keypad that will indicate the duration (in minutes) of the print, and then after three keys are pressed ('049' = 49 minutes; '143' = 143 minutes) I want the fan to kick on and stay on for 10 minutes beyond the print duration, and the LEDs to all light up and sequentially turn off in a row to indicate the progress of the print. All 10 lit means it just started, 5 lit means halfway done, etc...
I have successfully programmed the fan (w/ a transistor and diode to reach the Vin 12v) and LEDs (take minutes_entered and multiply by 6000, and then delay by this amount between each LED pulling to LOW).
The issue is with the keypad input. Alone, this section of the code outputs the right 3-digit number:
int time_in = 0;
void loop(){
if (isdigit(ch)){
uint8_t time_in = ch - '0';
time_in = ((time_in * 10) + time_in);
Serial.println(ch);
Serial.println(time_in);}}
When I attempt to integrate it into the rest, I get nonsensical outputs or no outputs, and the LEDs never turn on (although the fan does...).
If anyone spots my error, I will love you forever.
Full code:
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {39, 41, 43, 45}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {47, 49, 51}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int L1 = 52;
int L2 = 50;
int L3 = 48;
int L4 = 46;
int L5 = 44;
int L6 = 42;
int L7 = 40;
int L8 = 38;
int L9 = 36;
int L10 = 34;
int fan = 22;
int time_in = 0;
float Tbit;
pinMode(L1, OUTPUT);
pinMode(L2, OUTPUT);
pinMode(L3, OUTPUT);
pinMode(L4, OUTPUT);
pinMode(L5, OUTPUT);
pinMode(L6, OUTPUT);
pinMode(L7, OUTPUT);
pinMode(L8, OUTPUT);
pinMode(L9, OUTPUT);
pinMode(L10, OUTPUT);
pinMode(fan, OUTPUT);
int i;
char ch = keypad.getKey();
while (i < 3){
if (isdigit(ch)){
Serial.println(ch);
i = i++;}
Serial.print("i is");
Serial.println(i);
Tbit = time_in*6000;
digitalWrite(fan, HIGH);
digitalWrite(L1, HIGH);
digitalWrite(L2, HIGH);
digitalWrite(L3, HIGH);
digitalWrite(L4, HIGH);
digitalWrite(L5, HIGH);
digitalWrite(L6, HIGH);
digitalWrite(L7, HIGH);
digitalWrite(L8, HIGH);
digitalWrite(L9, HIGH);
digitalWrite(L10, HIGH);
delay(Tbit);
digitalWrite(L10, LOW);
delay(Tbit);
digitalWrite(L9, LOW);
delay(Tbit);
digitalWrite(L8, LOW);
delay(Tbit);
digitalWrite(L7, LOW);
delay(Tbit);
digitalWrite(L6, LOW);
delay(Tbit);
digitalWrite(L5, LOW);
delay(Tbit);
digitalWrite(L4, LOW);
delay(Tbit);
digitalWrite(L3, LOW);
delay(Tbit);
digitalWrite(L2, LOW);
delay(Tbit);
digitalWrite(L1, LOW);
delay(600000);
digitalWrite(fan, LOW);
