Using MAX30102 and MLX90614 Sensors
Hello everyone, I am attempting to use a MAX30102 heartbeat and SO2 sensor along with a MLX90614 temperature sensor on a raspberry pi pico. Using the sensors individually, I have no issues, but when I attempt to use both at the same time, I can only get the MAX30102 sensor to work. Doing some research, I think it's due to how MLX90614 sensor uses the wire protocol. I know that I can use Wire and Wire1, which I think would allow me to use both sensors, but I am not sure how to enable this on the pi pico. Any ideas on how I can get both to work?
Here is the code I am using:
#include <Wire.h>
#include "MAX30105.h"
#include <SparkFunMLX90614.h> //Click here to get the library: http://librarymanager/All#Qwiic_IR_Thermometer by SparkFun
#include "heartRate.h"
extern TwoWire Wire1;
MAX30105 particleSensor;
IRTherm therm; // Create an IRTherm object to interact with throughout
const byte RATE_SIZE = 8; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
unsigned long previousMillis = 0;
long interval = 550;
#define numReadings 10
float readings[numReadings];
uint8_t readIndex = 0;
bool fullArray = false;
float readings1[numReadings];
uint8_t readIndex1 = 0;
bool fullArray1 = false;
float beatsPerMinute;
int beatAvg;
  Wire.begin();
  therm.begin();
  therm.setUnit(TEMP_F);
  // Initialize Heartrate sensor
  particleSensor.begin(Wire, I2C_SPEED_FAST);
  particleSensor.setup(); //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
void temp()
  if (therm.read()) // On success, read() will return 1, on fail 0.
    if (readIndex == numReadings) {
      fullArray = true;
      readIndex = 0;
    readings[readIndex] = therm.object();
    readIndex++;
    uint8_t total;
    if (fullArray) total = numReadings;
    else total = readIndex;
    float average = 0;
    for (uint8_t i = 0; i < total; i++){
      average += readings[i];
    average = average / total;
    if (readIndex1 == numReadings) {
      fullArray1 = true;
      readIndex1 = 0;
    readings1[readIndex1] = therm.ambient();
    readIndex1++;
    uint8_t total1;
    if (fullArray1) total1 = numReadings;
    else total1 = readIndex1;
    float average1 = 0;
    for (uint8_t i = 0; i < total1; i++){
      average1 += readings1[i];
    average1 = average1 / total1;
    Serial.print(average);
    Serial.print(",");
    Serial.println(average1);
void loop(){
  long irValue = particleSensor.getIR();
  if (checkForBeat(irValue) == true)
    //We sensed a beat!
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    if (beatsPerMinute < 255 && beatsPerMinute > 20)
      rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
      rateSpot %= RATE_SIZE; //Wrap variable
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  Serial.print("IR=");
  Serial.print(irValue);
  Serial.print(", BPM=");
  Serial.print(beatsPerMinute);
  Serial.print(", Avg BPM=");
  Serial.print(beatAvg);
  if (irValue < 50000)
    Serial.print(" No finger?");
  temp();
first of all you should use names that are self-descriptive
what is the "particleSensor" ?? A sensor detecting SO2-paricles???
What does the IRTherm therm; object do
measuring temperatures???
Where is this temperature-sensor defined used in your code???
You are initialising the "therm"-object with no parameters.
I assume that then the term-object uses the standard I2C-bus and not the wire1
I guess you have taken just the example-codes delivered with the library.
These demo-codes are another example of how lazy the code-writer was in typing down a quick & dirty example-code
best regards Stefan
