Using MC14489 to drive two 7seg displays.
Hi
I have a MC14489 7Seg display driver, driving two displays.
The displays are wired to banks 1 and 5.
When i upload my code, the display flashes numbers and letters then goes blank.
I have tried to debug some info but get nothing through serial mon.
my coded returns no errors when verifying.
I am trying to make a simple counter 0 -99, at 1 sec intervals
here is my code
// Example 51.1
// Motorola MC14489 with HP 5082-7415 5-digit, 7-segment LED display
// 2k0 resistor on MC14489 Rx pin
// John Boxall 2013 CC by-sa-nc
// define pins for data from Arduino to MC14489
// we treat it just like a 74HC595
int data = 5;
int clock = 6;
int enable = 7;
int blank = 0;
int numa = 0;
int numb = 0;
 pinMode(data, OUTPUT);
 pinMode(enable, OUTPUT);
 pinMode(clock, OUTPUT);
 displayOn(); // display defaults to off at power-up
void displayTest1()
// displays 5.4321
 digitalWrite(enable, LOW); // send 3 bytes to display register. See data sheet page 9
 // you can also insert decimal or hexadecimal numbers in place of the binary numbers
 // we're using binary as you can easily match the nibbles (4-bits) against the table
 // in data sheet page 8
 shiftOut(data, clock, MSBFIRST, numa); // D23~D16
 shiftOut(data, clock, MSBFIRST, blank); // D15~D8
 shiftOut(data, clock, MSBFIRST, numb); // D7~D0
 digitalWrite(enable, HIGH);
 delay(10);
void displayOn()
// turns on display
 shiftOut(data, clock, MSBFIRST, B00000001);
 delay(10);
void displayOff()
// turns off display
 shiftOut(data, clock, MSBFIRST, B00000000);
 delay(10);
 displayOn();
 displayTest1();
if (numa < 9)
  numa++;
  numa = 0;
  numb++;
 Serial.print("A");
 Serial.print(numa);
 Serial.print("B");
 Serial.print(numb);
numa and numb are the displays while blank is a filler for unused banks.
any help would be greatfull.
More Serial.print() statements are the answer, then. Put one in setup(), showing that you got there. Put one or more at the top of loop(). Print the values of numa and numb EVERY time, until you know where the problem is.
It seems to me, though, that you would want to delay() every time through loop(), not just when numa is greater than 9.
numa and numb should be passed to the display function, and should be static in loop(), rather than global.
