Using MCP 23008 8 bits I/O Expander I2C
Here it´s a simple example:
Enjoy.
#include <Wire.h>
byte i2cAddr=B0100000;  //device address ID MCP23008
  Wire.begin();
  transmite(i2cAddr, 0, 0); //Todos los bits como salidas MCP23008
  transmite(i2cAddr, 0x09, B10101010); //Para el MCP23008
  transmite(i2cAddr, 0x09, B01010101);
void transmite(byte x, byte y, byte z) // dirección, GPIO registro, valor
  Wire.beginTransmission(x);
  Wire.write(y);//select GPIO register
  Wire.write(z);//set register value-all low
  Wire.endTransmission();
moderator: added code tags & indentation (use CTRL-T in IDE)
Thanks for sharing, I restyled the code a bit
to improve the code you could use descriptive variable names!
void transmite(byte address, byte register, byte value)
  Wire.beginTransmission(address);
  Wire.write(registery);
  Wire.write(value);
you see you do not need comments (or less comments) this way.
Even removed one incorrect comment - the one with all low!
