Using memcpy to save doubles to EEPROM
I am trying to save and retrieve doubles from the EEPROM memory, using the code below:
#include <EEPROM.h>
void setup(){
    Serial.println("Arduino has reset");
    double x = 13426.8888;
    Serial.print(x);
    Serial.println(" is about to be saved");
    saveDouble(x,0);
    double y = loadDouble(0);
    Serial.print(y);
    Serial.println(" has been loaded");
    int a = 456;
    Serial.print(a);
    saveInt(a,5);
    int b = loadInt(5);
    Serial.print(b);
void loop(){
int saveDouble(double toSave, int firstByte){
    char buffer[sizeof(double)];
    memcpy(&buffer,&toSave,sizeof(double));
    for (int i=0; i<sizeof(double); i++) {
        EEPROM.write(firstByte+i,buffer[i]);
    return 1;
int loadDouble(int firstByte){
    double loaded;
    for (int i = 0; i<sizeof(double);i++) {
        Serial.println(i);
        buffer[i] = EEPROM.read(i+firstByte);
    memcpy(&loaded,&buffer,sizeof(double));
    return loaded;
int saveInt(int toSave, int firstByte){
    char buffer[sizeof(int)];
    memcpy(&buffer,&toSave,sizeof(int));
    for (int i=0; i<sizeof(int); i++) {
    return 1;
int loadInt(int firstByte){
    int loaded;
    for (int i = 0; i<sizeof(int);i++) {
    memcpy(&loaded,&buffer,sizeof(int));
    return loaded;
At first I thought it was working, but then I changed the code to have doubles with decimal parts. Then the code only returns the whole part of the number.
I have managed to save using a different method (pointers and shizzle) but I am intrigued as to why this doesn't work, and why I am getting the whole number results. I assume I am missing a byte somewhere, but I cannot see how I can be.
Anyway, thanks in advance for any help.
No mystery at all.
    double loaded;
    return loaded;
Why doesn't the return type match the function name?
Aha. You are awesome (and I am stupid).
