Hi i'm having trouble using 'client.print' in a subroutine.
In the 'void loop' I'm using
'// Ethernet outputs here
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
//Serial.write(c); //dont need to feed back once working
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("");
client.println("");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv="refresh" content="5">");'
To start up the output to the client
then using
' client.print("System started ");
// need a method for the next set of lines as they will be used over and over
client.print("\t");
client.print(day(sEpoch));
client.print("/");
client.print(month(sEpoch));
client.print("/");
client.print(year(sEpoch));
client.print(" ");
buff = hour(sEpoch);
if (buff < 10) {
client.print ("0");
client.print(buff);
client.print(":");
buff = minute(sEpoch);
if (buff < 10) {
client.print ("0");
client.print(buff);
client.print(".");
buff = second(sEpoch);
if (buff < 10) {
client.print ("0");
client.print(buff);
client.println("
To send things off to the intranet
Now because this last bit is eventually going to be used 12 times over with different values of 'sEpoch' I would like to put it into a method all of its own like
void Clientprn(unsigned long t)
client.print("\t");
client.print(day(t));
client.print("/");
However when I do this the subroutine is just skiped over and nothing is sent out.
Sorry but the whole code including getting/converting the values of the analog inputs and getting NTP date time stamps is too long to attach.
Suggestions welcom.
