Using MFRC522 and HC-12 (with software Serial) at the same time doesn't work
Hey there,
I am trying to use the MFRC522 RFID-Reader in combination with the HC-12 wireless transreceiver on an Arduino Nano.
The RFID reader works as intended, but the HC-12 does not send or receive anything.
I already checked if the HC-12 is broken. It does function proberly when the MRFC522 library is not used.
Here are the important parts of my code:
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3,4); //RX, TX
  mySerial.begin(2400);
  delay(100);
  SPI.begin();          // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
bool testRFID() {
  if(mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()){
    String UID = "";
    for (byte i = 0; i < mfrc522.uid.size; i++) UID.concat(String(mfrc522.uid.uidByte[i], HEX));
  return false;
bool receive(){
  mySerial.listen();
  if(mySerial.available() > 1){
    String input = mySerial.readString();
    input.replace("\n", "");
    return uncode(input);
  return false;
void transmit(String msg){
    mySerial.println(msg);
All functions below setup() are called from time to time in loop().
The whole code is much longer, so I will attach it at the end. I should have quoted all important parts though.
I have used the HC-12 with software serial in the exact same configuration many times now and it always worked fine until I added the MFRC522...
If you know any solution to this problem, please tell me. I am fine with starting over if it works then...
Here you can see the whole code, which is probably pain to read into:
const String password = "NKHXDFQJ"; //8 characters long!!!
const String mySID = "000"; //Die Sensor ID des aktuellen Sensors. Handelt es sich nicht um einen Sensor, ist sie gleich 000
//Welche Karten alle erlaubt sind:
String allowed[] = {"4BF229AA54880","907155D3","4DE34FD3","C76E55D3"};
//Nicht ändern
String lastCmd = "000";         //Der letzte dekodierte Befehl
unsigned int lastSID = 99;      //Die letzte empfangene sensor ID
const String endCode = "XX";    //Das Terminator Kürzel fürs Ende eines Datenblocks
const unsigned int set = 2;
//Pin Zuweisungen
const unsigned int LEDg = 5,LEDr = 6,LEDy = 7;
const unsigned int LEDerr = A1;
const unsigned int notknopf = 8;
unsigned int state = 3;                     //0 = off,1 = on,2 = noClue,3 = switching
//Zeithandeling
const unsigned long waitForPing = 120000;   //Wie lange auf einen Ping gewartet wird bevor status = 2
unsigned long lastPing = 0;                 //Wann der letzte Befehl mitgelesen wurde
const unsigned long waitForStatus = 10000;  //How many millis to wait for a status after switching
unsigned long lastStatus = 0;               //Letztes Umschalten
const unsigned long wrongLEDTime = 2000;    //Wie lange die Error LED leuchtet wenn ne falsche Karte gezeigt wurde
unsigned long lastWrong = 0;                //Wann das letzte Mal eine falsche Karte gezeigt wurde
//Blinker
bool blinkAn = false;   //Ob jetzt gerade eine an-Periode ist
const unsigned long blinkDelay = 200; //Halbe Blink-Periode
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
#include <SoftwareSerial.h> //HC Kram
  delay(100);
  if(Serial){
    Serial.println("Configuration:");
    Serial.print("Password: ");
    Serial.println(password);
    Serial.print("Terminator: ");
    Serial.println(endCode);
    if(mySID != "000") {
      Serial.print("ID: ");
      Serial.println(mySID);
    Serial.println("--- Ende ---\n");
  pinMode(LED_BUILTIN,OUTPUT);
  pinMode(set,OUTPUT);
  digitalWrite(set,HIGH);
  if(Serial) Serial.println("ready!");
  pinMode(LEDg,OUTPUT);
  pinMode(LEDr,OUTPUT);
  pinMode(LEDy,OUTPUT);
  pinMode(LEDerr,OUTPUT);
  pinMode(notknopf,INPUT_PULLUP);
  transmit(encode("BUS"));
  if(!digitalRead(notknopf)){   //Notknopf
    while(!digitalRead(notknopf)) delay(10);
    for(unsigned int i = 0;i < 3;i++){
      transmit(encode("NFK"));
      delay(1500);
  commands();   //Befehle
  if(state != 3 && testRFID()){   //Umschalten
    lastStatus = millis();
    switch(state){
      case 0: //Turn on
        transmit(encode("SON"));
      case 1: //Turn off priority
        transmit(encode("SOP"));
      case 2:
    state = 3;
  if(state == 3 && millis() - lastStatus > waitForStatus){
  //Blinker
  blinkAn = millis() % (blinkDelay * 2) < blinkDelay;
  //LEDs
  digitalWrite(LEDr,state == 0);
  digitalWrite(LEDg,state == 1);
  digitalWrite(LEDy,state == 2 || state == 3 && blinkAn);
  digitalWrite(LEDerr,millis() - lastWrong < wrongLEDTime && lastWrong != 0);
void commands(){    //Befehlsverarbeitung
  if(!receive) return;
    if(lastCmd == "PNG"){  //Check for pings
      lastPing = millis();
    if(lastCmd == "ANN"){
      state = 1;
    if(lastCmd == "AUS"){
      state = 0;
    if(lastCmd == "ALM"){
      state = 1;
    if(lastCmd == "LED"){
      for(int i = 0;i < 20;i++){
        digitalWrite(LEDr,i%4 == 0);
        digitalWrite(LEDg,i%4 == 1);
        digitalWrite(LEDy,i%4 == 2);
        digitalWrite(LEDerr,i%4 == 3);
        delay(50);
bool testRFID() {   //Teste ob eine gültige Karte vorgelegt ist. Wenn ja, return true. Sonst return false.
    String UID = "";
    UID.toUpperCase();
    if(Serial) Serial.println(UID);
    if(UID == "5B49E243" || UID == "BB385844" || UID == "46A299AA54880" || UID == "4712A9AA54880") return true;
    for(byte i = 0;i < sizeof(allowed)/sizeof(allowed[0]);i++) if(allowed[i] == UID)return true;
  return false;
//Teste ob was empfangen werden kann
bool receive(){
  mySerial.listen();
    if(Serial) Serial.println(input);
  return false;
//Sende etwas
    if(Serial) Serial.println(msg);
//Gibt eine Befehlseingabe kodiert zurück
String encode(String cmd,String sID){ //Befehl und Sensor ID
  return password + cmd + sID + endCode;
String encode(String cmd){
  return encode(cmd,mySID);
//Etwas empfangenes zerpflücken
bool uncode(String msg){
  msg.toUpperCase();
  //Password test
  String temp = "";
  for(unsigned int i = 0;i < 8;i++){
    temp += msg.charAt(i);
  if (temp != password) {
    Serial.println("Received, but password not matching");
    return false;
  //Terminator test
  temp = "";
  for(unsigned int i = 14;i < 16;i++){
  if (temp != endCode) {
    Serial.println("Received, but terminator not matching");
    return false;
  temp = ""; //Command
  for(unsigned int i = 8;i < 11;i++){
  lastCmd = temp;
  temp = ""; //sID
  for(unsigned int i = 11;i < 14;i++){
  lastSID = temp.toInt();
  return true;
Thank you for taking your time :slight_smile:
