Using MFRC522 with a MKRZERO board
Hi all,
I'm trying to connect a RFD reader MFRC522 to a MKRZERO board. After some digging, I have the 2 following questions:
  1. GPIO0 in ESP8266 (or D3 in Wemos D1 mini) to what PIN on MKRZERO is equivalent? As you can see in the following code, I need to change the "RST_PIN D3" (for Wemos D1 mini) to the corresponding value for the MKRZERO, and I'm a bit lost there.
  2. Also, I'm not sure how to define it on the code. The original code states:
#define RST_PIN  D3 // RST-PIN GPIO4
#define SS_PIN  D8  // SDA-PIN GPIO2
In MKRZERo the SS_PIN (D8) translates to "11 SDA", but I'm not sure how to define this on the code. Any thougts?
This is the full program (from here):
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <SPI.h>
#include "MFRC522.h"
/* wiring the MFRC522 to ESP8266 (ESP-12)
RST     = GPIO4
SDA(SS) = GPIO2
MOSI    = GPIO13
MISO    = GPIO12
SCK     = GPIO14
GND     = GND
3.3V    = 3.3V
RGB LED Setup
Red LED   = D1
Ground    = GND
Gr. LED   = D2
Blue LED  = D0
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
// Wifi Connection details
const char* ssid = "xxxxx";
const char* password = "xxxxxx";
const char* mqtt_server = "xxxxxxx";
const char* mqtt_user = "xxxxxxx";
const char* mqtt_password = "xxxxxxxx";
const char* clientID = "RFID";
const char* rfid_topic = "home/rfid";
const int redPin = D1;
const int greenPin = D2;
const int idPin = D0;
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
  SPI.begin();           // Init SPI bus
  mfrc522.PCD_Init();    // Init MFRC522
  pinMode(redPin, OUTPUT); // Red LED
  pinMode(redPin, HIGH);
  pinMode(greenPin, OUTPUT); // Green :LED
  pinMode(greenPin, HIGH);
  pinMode(idPin, OUTPUT); // ID :LED
  pinMode(idPin, HIGH);
  delay(2);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
// Connect to Wifi
void setup_wifi() {
  //Turn off Access Point
  WiFi.mode(WIFI_STA);
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
// Check for incoming messages
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.println("");
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  char s[20];
  sprintf(s, "%s", payload);
    if ( (strcmp(topic,"home/alarm")==0))
    payload[length] = '\0';
    String sp = String((char*)payload);
  // Alarm is off
    if (sp == "disarmed")
    Serial.print("Alarm is set to Disarmed");
    off_both_led();
  // Alarm is Armed Home
    else if (sp == "armed_home")
    Serial.print("Alarm is set to Armed Home");
    on_green_led();
  // Alarm is arming
      else if (sp == "pending")
    Serial.print("Alarm set to Pending");
    on_both_led();
  // Alarm is Armed Away
    else if (sp == "armed_away")
    Serial.print("Alarm set to Armed Away");
    on_green_led();
  // Alarm is Triggered
    else if (sp == "triggered")
    Serial.print("Alarm is triggered!!");
    on_red_led();
/* interpret the ascii digits in[0] and in[1] as hex
* notation and convert to an integer 0..255.
int hex8(byte *in)
   char c, h;
   c = (char)in[0];
   if (c <= '9' && c >= '0') {  c -= '0'; }
   else if (c <= 'f' && c >= 'a') { c -= ('a' - 0x0a); }
   else if (c <= 'F' && c >= 'A') { c -= ('A' - 0x0a); }
   else return(-1);
   h = c;
   c = (char)in[1];
   else return(-1);
   return ( h<<4 | c);
// Reconnect to wifi if connection lost
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(clientID, mqtt_user, mqtt_password)) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("home/rfid", "connected");
      // ... and resubscribe
      client.subscribe("home/alarm");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
// Main functions
  if (!client.connected()) {
    reconnect();
  client.loop();
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    delay(50);
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    delay(50);
    return;
  // Show some details of the PICC (that is: the tag/card)
  Serial.println("");
  Serial.print(F("Card UID:"));
  dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
  digitalWrite(idPin, HIGH);
  digitalWrite(idPin, LOW);
  // Send data to MQTT
  String rfidUid = "";
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    rfidUid += String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "");
    rfidUid += String(mfrc522.uid.uidByte[i], HEX);
  const char* id = rfidUid.c_str();
  client.publish("home/rfid", id);
  delay(3000);
// LED Loop
void off_both_led(){
  Serial.println("Turning off all led");
  digitalWrite(greenPin, LOW);
  digitalWrite(redPin, LOW);
void flash_green_led(){
  Serial.println("Flashing Green LED");
  // Flash 15 times:
  for(int i = 0; i < 14; i++)
  digitalWrite(greenPin, HIGH);
void flash_red_led(){
  Serial.println("Flashing Red LED");
  // Flash 20 times:
  for(int i = 0; i < 19; i++)
  digitalWrite(redPin, HIGH);
void on_green_led(){
  Serial.println("Turning on green led");
void on_red_led(){
  Serial.println("Turning on red led");
void on_both_led(){
  Serial.println("Turning on both led");
// Helper routine to dump a byte array as hex values to Serial
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
The "corresponding value" for the MKRZERO would be the pin that you connected the reset pin to.
Nonsense. "11 SDA" is NOT a number. D8 is a value. You may not know what the value is, but you can be sure that it is a numeric value, like 11 is.
So I guess my question was more about if I can use any pin or there is some specific pins designed for this kind of things. I just was looking for a suggestion.
So, if for Wemos D1 mini the value D8 is correct (is very easy to find the "pinout" on the internet), but for MKRZERO doesn't seem so easy for me. All I could find is: Where is the PINOUT for MKR Zero? - MKRZero - Arduino Forum and ArduinoCore-samd/variants/mkrzero/variant.cpp at 1.6.16 · arduino/ArduinoCore-samd · GitHub and it's not clear enough what value to use. For example for A6 the value could either be: 21, A6 or PA07. Any thoughts?
The name A6 has a value. Print the value (Serial.print("A6 = ");Serial.println(A6):wink: to see what it is. Your question might become a lot simpler.
