using microphone to control 3v DC motor speed
Hello,
all goes well with the project.
I would, however, still like to be able to check up on the amplitude value coming from the amp via serial communication, in order to fine tune and understand things a little further.
in a previous reply you mention that I should
"check the conversion time for the A/d converters in the Atmega datasheet. You might not be catching things quickly enough"
I was wondering if you (or anyone else) could elaborate on this a little as I'm not sure what to do about it. I checked the datasheet:
The conversion times for the a/d converters on the Atmega are "13 - 260 [ch956]s Conversion Time"
I'm not really sure what this means, or what to do about it. Baud rates?
any help is greatly appreciated.
