Using MicroSD card on SPI0 hardware pins
From the documentation:
There’s an extended mode where you can swap the normal pins to the SPI0 hardware pins. This is enabled by calling
SPI.pins(6, 7, 8, 0) before the call to SPI.begin(). The pins would change to:
• MOSI = SD1
• MISO = SD0
• SCLK = CLK
• HWCS = GPIO0
I have tried unsuccessfully to get this to work. When I boot without an SD card in the slot I get:
begin() failed
Do not reformat the SD.
No card, wrong chip select pin, or wiring error?
SdError: 0X1,0XFF
When I boot with an SD card in the slot, I get:
begin() failed
SdError: 0X6,0XFF
My code:
  Serial.begin(230400);
  Serial.swap();
  Serial1.begin(9600);
  SPI.pins(6, 7, 8, 0);
  SPI.begin();
  if (!SD.begin(0)) {
    SD.initErrorPrint(&Serial1);
    return;
  Serial1.printf("\n\nSDC Card Initialized\n\n");
The reason for using the SPI0 hardware pins is because I need GPIO13 and GPIO15 for RXD2 and TXD2 connection to a MAX232 and DE9.
I also have random problems with booting and flashing with an SD card installed.
Does anyone have any sample code that is known to work?
from where is that documentation and to what MCU exactly does it apply?
ESP8266 Arduino Core Documentation
Release 3.1.2-21-ga348833
Ivan Grokhotkov
Aug 29, 2023
4.5 SPI
SPI library supports the entire Arduino SPI API including transactions, including setting phase (CPHA). Setting the Clock polarity (CPOL) is not supported, yet (SPI_MODE2 and SPI_MODE3 not working).
The usual SPI pins are:
• MOSI = GPIO13
• MISO = GPIO12
• SCLK = GPIO14
There’s an extended mode where you can swap the normal pins to the SPI0 hardware pins. This is enabled by calling SPI.pins(6, 7, 8, 0) before the call to SPI.begin(). The pins would change to:
• MOSI = SD1
• MISO = SD0
• SCLK = CLK
• HWCS = GPIO0
This mode shares the SPI pins with the controller that reads the program code from flash and is controlled by a hardware arbiter (the flash has always higher priority). For this mode the CS will be controlled by hardware as you can’t handle the CS line with a GPIO, you never actually know when the arbiter is going to grant you access to the bus so you must let it handle CS automatically
11.20 NodeMCU 1.0 (ESP-12E Module)
This module is sold under many names for around $6.50 on AliExpress and it’s one of the cheapest, fully integrated ESP8266 solutions. It’s an open hardware design with an ESP-12E core and 4 MB of SPI flash.
According to the manufacturer, “with a micro USB cable, you can connect NodeMCU devkit to your laptop and flash it without any trouble”. This is more or less true: the board comes with a CP2102 onboard USB to serial adapter which just works, well, the majority of the time. Sometimes flashing fails and you have to reset the board by holding down FLASH + RST, then releasing FLASH, then releasing RST. This forces the CP2102 device to power cycle and to be re-numbered by Linux.
The board also features a NCP1117 voltage regulator, a blue LED on GPIO16 and a 20k/100k Ohm voltage divider on the ADC input pin. The ESP-12E usually has a led connected on GPIO2.
Try adding a delay and try to init the sd card again.
multiple times.
I read this section to mean don't do this because it will probably be unreliable.
Yah, clear as mud. Maybe the documentation should not even mention "extended mode where you swap the normal pins to the SPI0 hardware pins", since it seems you can't.
I have decided that the ESP8266 will not do what I need it to do (external serial port and SD card). I'm now looking at the ESP32.
Thank you for the help.
not many devices can use this. displays were an example doing refresh between flash memory access
I would love to see code that does this.
