Hello all.
I'm very new to Arduino, and i'm attempting to use SonicRobot's midi to dmx shield/code to output DMX values from Midi generated by a midi controller.
Sadly the controller's faders do not generate note values, only CC values. Is it the case that the declarations can be changed so the existing code would work with CC values? I've done some googling/forum searching and couldn't find anything especially useful
(Some background: I'm attempting to use a midi controller (behringer BCF2000) to add extra faders to a lighting console (GrandMA2 Ultralite)
Here's the original code
// welcome to MIDI to DMX by moritz Simon geist.
// Ressources, setup and hardware: http://sonicrobots.com/?p=864
// DmxSimple is available from: http://code.google.com/p/tinkerit/
// Help and support: http://groups.google.com/group/dmxsimple */
#include <DmxSimple.h>
byte incomingByte;
byte note;
byte velocity;
int statusLed = 13; // select the pin for the LED
int action=2; //0 =note off ; 1=note on ; 2= nada
pinMode(statusLed,OUTPUT); // declare the LED's pin as output
//start serial with midi baudrate 31250 or 38400 for debugging
Serial.begin(31250);
/* The most common pin for DMX output is pin 3, which DmxSimple
** uses by default. If you need to change that, do it here. */
DmxSimple.usePin(3);
/* DMX devices typically need to receive a complete set of channels
** even if you only need to adjust the first channel. You can
** easily change the number of channels sent here. If you don't
** do this, DmxSimple will set the maximum channel number to the
** highest channel you DmxSimple.write() to. */
DmxSimple.maxChannel(5);
void loop () {
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// wait for as status-byte, channel 1, note on or off
if (incomingByte== 144){ // note on message starting starting
action=1;
}else if (incomingByte== 128){ // note off message starting
action=0;
}else if (incomingByte== 208){ // aftertouch message starting
//not implemented yet
}else if (incomingByte== 160){ // polypressure message starting
}else if ( (action==0)&&(note==0) ){ // if we received a "note off", we wait for which note (databyte)
note=incomingByte;
playNote(note, 0);
note=0;
velocity=0;
action=2;
}else if ( (action==1)&&(note==0) ){ // if we received a "note on", we wait for the note (databyte)
note=incomingByte;
}else if ( (action==1)&&(note!=0) ){ // ...and then the velocity
velocity=incomingByte;
playNote(note, velocity);
note=0;
velocity=0;
action=0;
}else{
//nada
void playNote(byte note, byte velocity){
int value=0;
if (velocity >10){
value=255;
}else{
value=0;
// =DEVICE 1=
// DMX CHANEL 1: "2" for seting DMX Mode
// DMX CHANEL 2: 0 .. 255 Control Red --> .... MIDI Note "1" (possible C-2)
// DMX CHANEL 3: 0 .. 255 Control Green --> .... MIDI Note "2"
// DMX CHANEL 4: 0 .. 255 Control Blue --> .... MIDI Note "3"
// DMX CHANEL 5: NADA
// =DEVICE 2=
// DMX CHANEL 8: "2" for seting DMX Mode
// DMX CHANEL 9: 0 .. 255 Control Red --> .... MIDI Note 4
// DMX CHANEL 10: 0 .. 255 Control Green --> .... MIDI Note 5
// DMX CHANEL 11: 0 .. 255 Control Blue --> .... MIDI Note 6
// DMX CHANEL 12: NADA
// ADAPT THIS to match your Midi Notes to your DMX Channels
if(note>=1 && note<10){
switch (note) {
case 1:
DmxSimple.write(2, velocity);
case 2:
DmxSimple.write(3, velocity);
case 3:
DmxSimple.write(4, velocity);
case 4:
DmxSimple.write(9, velocity);
case 5:
DmxSimple.write(10, velocity);
case 6:
DmxSimple.write(11, velocity);
//[ ... ] add more channels
