Hi, I am new with Arduino. I need some advice or help. I am currently busy with a management project, using a 4x4 Keypad and a 8 Channel Relay module. For now I am only starting with 2 relays and later duplicate it when I get the issue sorted. When it is just the Press and Release part of the code the relays activate, but when I add the Millis part of the code the relays does not want to activate and only the LED on that channel flashes, but when pressing key 'A' the relay activates.
#include <Keypad.h>
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {22, 23, 24, 25}; // Connect to the row pinouts of the keypad
byte colPins[COLS] = {26, 27, 28, 29}; // Connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
byte relayPin1 = 9;
byte relayPin2 = 8;
unsigned long relayOffTime = 0; // variable to store the time when the relays were turned off
Serial.begin(9600); // Initialize serial communication
pinMode(relayPin1, OUTPUT);
pinMode(relayPin2, OUTPUT);
// Initialize relays to OFF state
digitalWrite(relayPin1, HIGH);
digitalWrite(relayPin2, HIGH);
keypad.addEventListener(keypadEvent);
unsigned long startTime = 0; // variable to store the start time when a key is pressed
unsigned long duration = 200; // duration for which relays stay on (in milliseconds)
unsigned long currentMillis = millis(); // get the current time
char key = keypad.getKey(); // get the key
if (key) {
Serial.println(key); // print the key to Serial monitor
switch (key) {
case 'A':
digitalWrite(relayPin1, LOW); // turn on relay 1
digitalWrite(relayPin2, LOW);
startTime = currentMillis; // store the current time
// add cases for other keys as needed
default:
// check if it's time to turn off the relays
if (currentMillis - startTime >= duration) {
// turn off all relays
void keypadEvent(KeypadEvent key){
//char key = keypad.getKey(); // Get the pressed key
switch (keypad.getState()){
case PRESSED:
if (key == '1') {
digitalWrite(relayPin1,LOW);
case RELEASED:
if (key == '1') {
digitalWrite(relayPin1,HIGH);
/* FRONT UP */
case PRESSED:
if (key == '2') {
digitalWrite(relayPin2,LOW);
case RELEASED:
if (key == '2') {
digitalWrite(relayPin2,HIGH);
