Using millis for counting and cummulating a button push time
I am trying to find a simple way to accumulate the time a button is pushed.
Here is what I came up with:
unsigned long BeforeMillis = 0;
unsigned long CumulatedUpTime;
#define BUTTON_PIN 14 // Blue - pluse of the timer comes from the cord
#define Second_Button 15 //Wire to the Reject switch
Serial.print("Ready ");
pinMode(BUTTON_PIN, INPUT_PULLUP);
unsigned long NowMillis = millis();
while (digitalRead (BUTTON_PIN) ==0) // "0" means button Pushed
if (NowMillis - BeforeMillis>=1000 )
{ BeforeMillis = NowMillis;
CumulatedUpTime++;
Serial.print("CumulatedUpTime = ");
Serial.println(CumulatedUpTime);
Serial.print("digitalRead (BUTTON_PIN) = ");
Serial.println(digitalRead (BUTTON_PIN));
What happens: When I push button, cummulated time increments by one and the entire loop stops, including serialPrint.
What I wish for: As button is pushed, the CumulatedUpTime would increase every second and be shown in serial Print as CumulatedUpTime= 2 , 3, 4..etc
Please help
thanks
NowMillis doesn't change in your while loop. So your while loop is frozen in time constantly comparing to the same Now.
That doesn't need to be a while loop. The loop function is already repeating. Take advantage of that.
Pseudocode (untested)
loop
 if button is depressed
    if millis - lastmillis > 0
       cumulativeCount += 1
       lastmillis = millis
Thanks
I came up with this and it works
if (NowMillis - BeforeMillis >= 1000 )
if (digitalRead (BUTTON_PIN) == 0) // Pressed
{ CumulatedUpTime++;
CumulatedUpTime = CumulatedUpTime;
Serial.print(CumulatedUpTime);
Serial.print("digitalRead ( BUTTON_PIN) = ");
Really? What do you think this does?
And here it is better formatted and in code tags. OP please note
      CumulatedUpTime++;
A question for you
Why do this ?
Wouldn't it be a lot simpler to record the value of millis() when the button is pressed and record it again to a different variable when the button is released? The difference between the two values will be the time it was pressed.
...R
