Using Millis for timing always returns 1 second
I am very very new to Arduino but have been a developer for years. Using Millis() to time is quite different than I would on the web.
Here is what I got
// Board Setup
int tiltPin   = 1;
// Global Setup
int tiltState  = 0;
int totalTime  = 0;
unsigned long startTimer   = 0;
unsigned long endTimer    = 0;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv != "1.0.0") {
    Serial.println("Please upgrade the firmware");
  tiltState = digitalRead(tiltPin);
   //If we are tilted
  if (tiltState == HIGH) {
    Serial.println("Tilting");
    startTimer = millis();
    Serial.println("Done Tilting");
    if( startTimer > 0 ){
      endTimer =  millis();
      totalTime = (endTimer - startTimer)  / 1000.0;
    if( totalTime > 0 ){
         testTime();
  delay(100);
 *Helper Functions
void testTime(){
    Serial.println("\nCalculating time ...");
    Serial.println("\nStart time");
    Serial.println(startTimer);
    Serial.println("\nEnd time");
    Serial.println(endTimer);
    Serial.println("\nTotal time");
    Serial.println(totalTime);
     totalTime   = 0;
     startTimer  = 0;
     endTimer   = 0;
To me this should work since I grab time in one function, then again when the tilt is done. Every time I run this no matter if it reads "tilting" for 10 seconds the equation returns 1 second. So the startTime and endTime doesnt seem to be recoding the actual time between the HIGH and LOW switch. I think it might be something with delay but again, I am very new.
Some of the retunred data:
Start time
61550
End time
62750
Total time
1
Start time
52250
End time
53450
Total time
1
Start time
12350
End time
13550
Total time
1
All those printed values are correct. What would you expect to see?
You have to be careful with your types. Consider the following.
  unsigned long startTime = 61550UL;
  unsigned long endTime = 62750UL;
  Serial.print("time 1: ");
  Serial.println((endTime - startTime) / 1000.0);
  int totalTime = (endTime - startTime) / 1000.0;
  Serial.print("time 2: ");
Serial monitor:
time 1: 1.20
time 2: 1
@DKWatson one of those outputs was after 10 seconds of the the tilt being done so I would expect the startTime and endTime to be 10000 milis apart. I get the math is right, just the start and end time are not reflecting the true amount of time between when the switch goes from HIGH to LOW
Delta_G:
Your code indicates that it should also print "Tilting" and "Done Tilting" when it records those times. But I don't see that in the output. Are you sure you're not getting more than one trigger to start in that ten seconds?
Ahhh so it reads out "Tilting" over and over while its tilting. I guess that would allow me to assume its declaring startTimer over and over again so the output is right since its re-assigned all the time. How do I get it to just set startTimer once its tilted and not over and over while its tilted?
Delta_G:
That will be true on each pass of loop while tilting. So it starts tilting and you get a start time. Then you Delay 1 second. Then loop repeats, the digitalRead is still giving HIGH so you get a new start time, even though you really started a second before. On each pass of loop you replace your start time until you finally stop tilting. So you're not timing from the time it started tilting. You're timing from the last time the loop function ran.
Study the state change example. You want to get a start time only when the sensor first reads HIGH. That is, when it reads HIGH this time but didn't last time. The State Change Example in the IDE shows an easy way to handle thatby keeping track of the last value you read.
Yep, I just realized that and posted while you posted this. I will take a look at the example.
