Hello there,
I've been working on a code for a while now and are close to finishing it now.
Yet I have stumbled upon the delay function problem and on replacing it with millis,
using it on smaller programs i never had problems integrating the millis function(classical blinking etc.),
but in my recent code i have a delay(1500); which completely messes up my code, and since I have only used millis on smaller programs I'm completely lost here, not even google was able to help me out on millis in bigger codes:(
For my code: I've creted a more simplified version of the code without the other loops in it. I would be very grateful if anyone could show me on how to use the millis function on the delay(1500); part, so i can study it and then apply it on the rest of the code of mine.
Without further a do here is the code:
const int buttonPin = A3; // the number of the pushbutton pin
const int motor = 13;
const int ledrd = A4; // the number of the LED pin
const int ledorange = 12;
const int linmotRaus = A1;
const int linmotRein = A2;
const int Sensor360 = 6;
// variables will change:
int buttonState = 0;
int buttonstateSensor360 = 0; // variable for reading the pushbutton status
int zahl = 5;
int ctu;
int var;
int var1;
// initialize the LED pin as an output:
pinMode(motor, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
pinMode(ledrd, OUTPUT);
pinMode(linmotRaus, OUTPUT);
pinMode(linmotRein, OUTPUT);
pinMode(ledorange, OUTPUT);
pinMode(Sensor360, INPUT);
buttonState = digitalRead(buttonPin);
buttonstateSensor360 = digitalRead(Sensor360);
if (buttonState == HIGH) {
ctu++;
delay(200);
//Serial.println(ctu);Serial.println(var); Serial.println(var1);Serial.println(zahl);
Serial.println((ctu == 3) && (var1 < zahl));
if ((ctu == 1) && (var < zahl)) {
digitalWrite(motor, HIGH);
digitalWrite(ledrd, HIGH);
if (buttonstateSensor360 == HIGH) {
digitalWrite(linmotRaus, HIGH);
var ++;
delay(1500);
digitalWrite(linmotRaus, LOW);
delay(100);
} else if ((ctu == 3) && (var1 < zahl)) {
digitalWrite(linmotRein, HIGH);
var1++;
delay(1500);
digitalWrite(linmotRein, LOW);
digitalWrite(motor, LOW);
digitalWrite(ledrd, LOW);
// var=0;
delay(100);
//-------------------------------------------------------------rein
Thanks in advance and have a great week
