After spending some time searching the internet and finding nothing, I decided to use the forum.
I’m trying to make the following work: I want to use the Serial Monitor to send a message to the Arduino, to which it should react. In that reaction, I would like to use a timer (with millis() ). The problem I seem to have is that my function is only called once, of that the timer does not work, I don’t not. I’m new to the millis()-function, but this is the first time I couldn’t fix the problem myself …
If there is another way to do what I want to do, which is, simply put, making my led blink once after typing something in to the serial monitor, please do tell.
(my project is more complicated than the example, the LED is an RGB-strip, but I think this is easier to use on the forum).
Any tips are welcome!
My code (for now):
int blinkTime = 1000;
pinMode(13, OUTPUT);
if (Serial.available() > 0) {
testSerial(Serial.readString());
void testSerial(String test) {
if (test.equals("1")) Serial.println("1 ingegeven");
else if (test.equals("2")) Serial.println("2 ingegeven");
else if (test.equals("3")) blinkLedOnce();
void blinkLedOnce() {
Serial.println("BlinkTest begonnen");
while (currentMillis <= 2 * blinkTime + 1) {
digitalWrite(13, LOW);
if (currentMillis >= blinkTime && currentMillis < 2 * blinkTime) digitalWrite(13, HIGH);
else if (currentMillis >= 2 * blinkTime) digitalWrite(13, LOW);
Serial.println("BlinkTest gestopt");
Maybe this example will help with your BWD programming.
//Blink without Delay skeleton
//4 examples demonstrated
//LED wiring options
//Depending which way your LEDs are wired, uncomment the next line.
//#define PlusEqualsON
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON LOW
#define ledOFF HIGH
#endif
//switch wiring options
//Depending which way your switches are wired, uncomment the next line.
#define PushEqualsLOW
#ifdef PushEqualsLOW
//pushing the switch makes pin LOW
#define Pushed LOW
#define Released HIGH
#else
//pushing the switch makes pin HIGH
#define Pushed HIGH
#define Released LOW
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL; //100ms
unsigned long ledOnTime = 5*1000UL; //5 seconds
byte laststartSwitchState = HIGH;
byte buttonState = HIGH;
byte counter = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch = 3; //pushed = LOW
digitalWrite(13,ledOFF);
digitalWrite(12,ledOFF);
pinMode(12, OUTPUT);
digitalWrite(11,ledOFF);
pinMode(11, OUTPUT);
digitalWrite(10,ledOFF);
pinMode(10, OUTPUT);
pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
pinMode(testSwitch, INPUT_PULLUP); //pushed = LOW
} // >>>>>>>>>>>>>> E N D O F s e t u p ( ) <<<<<<<<<<<<<<<<<
//save the current time
//************************************* E x a m p l e 1
//toggle pin 13 every 200mS
//has 200ms or more gone by?
if (currentMillis - pin13Millis >= 200UL)
//code here runs every 200ms
//get ready for next iteration
pin13Millis = pin13Millis + 200UL;
//toggle pin 13
digitalWrite(13,!digitalRead(13));
//************************************* E x a m p l e 2
//at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
//could be used as a powerup reset signal
if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
//code here runs for 3 seconds after power up, then stops
digitalWrite(12,ledON);
//disable further pin 12 control
flag12 = false;
//************************************* E x a m p l e 3
//if testSwitch is pushed and released
//pin 11 LED goes ON for 5 seconds, then goes OFF
buttonState = digitalRead(testSwitch);
//are we are allowed to check the switch and is it pressed?
if(flag11 == true && buttonState == Pushed)
//enable timing of LED on pin 11
flag11 = false; //false --> timing is enabled
//turn LED ON
digitalWrite(11,ledON);
//record the time LED turned ON
pin11Millis = currentMillis;
//are we allowed and is it time to control pin 11
if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
//if enabled, code here runs after ledOnTime ms goes by
//allow switch press detection again
flag11 = true; //true --> switch monitoring is enabled
//************************************* E x a m p l e 4
//is it time to check the switches?
//in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
if (currentMillis - SwitchMillis >= debounceMillis)
//code here runs every debounceMillis ms
//get ready for the next iteration
SwitchMillis += debounceMillis;
//go and check the switches
checkSwitches();
//put other non-blocking stuff here
} // >>>>>>>>>>>>>> E N D O F l o o p ( ) <<<<<<<<<<<<<<<<<
// F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
//re-usable for all the switches
boolean thisState;
//************************************* E x a m p l e Push ON push OFF (toggle)
//check if this switch has changed state
thisState = digitalRead(startSwitch);
if (thisState != laststartSwitchState)
//update the switch state
laststartSwitchState = thisState;
//this switch position has changed so do some stuff
//"HIGH condition code"
//switch went from LOW to HIGH
if(thisState == HIGH)
//Do some HIGH switch stuff here
//"LOW condition code"
//switch went from HIGH to LOW
//Do some LOW switch stuff here
digitalWrite(10, !digitalRead(10));
//print number of pushes
counter++;
Serial.println(counter);
} //END of startSwitch code
//similar code for other switches goes here
} //END of checkSwitches()
// E N D O F C O D E
@ LarryD: My whole sketch is 317 lines. I always try to break-up the code until a new piece works before I put it all together. The only thing I’m going to change is the “digitalWrite(13, LOW);” command to “ledStateRood = 255;” or something like that.
@ Robin2: works like a charm! Calling the function from inside the loop() like that fixed my problem, thanks! And thanks for the quick response, I didn’t expect to have an answer so soon.
The resulting code is (for those interested):
int blinkLengthMillis = 1000;
unsigned long blinkStartMillis = 0;
boolean blinkOn = false;
blinkLedOnce();
else if (test.equals("3")) {
blinkOn = true;
blinkStartMillis = millis();
if (blinkOn == true) {
if (millis() - blinkStartMillis >= blinkLengthMillis) {
blinkOn = false;
