Using millis to add 1 minute relay delay
First of all, I'm doing this to prevent my solenoid from turning on and off too often and burning out.
I'm making a thermostat that kicks on a solenoid+relay when the realTemperature goes below my setTemperature and I'm having some trouble coming up with the right code to give the solenoid a one minute delay after it hits the SetTemperature before coming back on again. For some reason, this code doesn't seem to be working... Any thoughts?
void relaySwitcher(int realTemperature, int tempSetting, int relay){
  unsigned long currentMillis=millis();
  unsigned long interval=60000;
  unsigned long previousMillis = 0;
  if (currentMillis - previousMillis >= interval){
      if (actualValue < sliderSetting) {
        digitalWrite(relay, HIGH);
        digitalWrite(relay, LOW);
put that above the void setup() area. you need to keep it, otherwise it resets everytime
You:
then you:
in the next call to the function.
What do you think will happen?
enum State {
  OFF = 0,
  DELAYING = 1,
  ON = 2
} state;
unsigned long delayingFromMs;
  state = OFF;
  switch(state) {
  case OFF:
    if(tempIsLow()) {
      state = DELAYING;
      delayingFromMs = millis();
    else {
      // do nothing;
  case DELAYING:
    if(tempIsLow()) {
      if(millis() - delayingFromMs > 1000L * 60L) {
        turnSolenoidOn();
        state = ON;
    else {
      state = OFF;
  case ON:
    if(tempIsLow()) {
      // do nothing
    else {
      turnSolenoidOff()l
      state = OFF;
The place to change the last event time is when the event occurs, not when some amount of time has elapsed. Obviously currentMillis and previousMillis are stupid names since they do not reflect what they actually contain.
Is there any hysteresis in your thermal control loop?
You all are the coolest. I decided to give enum a try because it seems awesome (This is one of my first coding projects so everything seems awesome).
As of now, it's working as I want. My new question, as I need to sort of triple this code to account for humidity levels (h), humidity solenoids (humdRelay), carbon dioxide levels (co2) and my co2 fresh air intake relay (co2Relay), is:
How do I go about turning my loop-embedded switch function into something more general that can be called 3 times using different variables each time?
I should also say, I'm using this code in conjunction with the Blynk app for and using it to display my temperature as well as provide a virtual thermostat from my phone...
Here's what I have:
#include <Bridge.h>
#include <BlynkSimpleYun.h>
#include <Wire.h>
#include "SparkFunHTU21D.h"
#include "kSeries.h"
#include <SimpleTimer.h>
SimpleTimer timer;
HTU21D myClimate;
int tempSlider = 30;
int tempRelay = 10;
int t;
enum State {
  OFF = 0,
  DELAYING = 1,
  ON = 2
} state;
char auth[] = "derp";
  Blynk.begin(auth);
  state = OFF;
  pinMode(tempRelay, OUTPUT);
  myClimate.begin();
BLYNK_READ(0) {  // temp display
  float celsiusTemp = myClimate.readTemperature();
  t = (celsiusTemp * 9.0) / 5.0 + 32.0; //convert to fahrenheit
  Blynk.virtualWrite(0, t);
//Temperature Setting in Blynk on Virtual Pin 2
BLYNK_WRITE(2) {
  tempSlider = param.asInt();
  Blynk.run();
  switch (state)
    case OFF:
      if (t < tempSlider) {
        state = DELAYING;
    case DELAYING:
        if (millis() - delayingFromMs > 1000L * 60L) {
          digitalWrite(tempRelay, HIGH);
          state = ON;
      else {
        state = OFF;
    case ON:
          // do nothing
          digitalWrite(tempRelay, LOW);
          state = OFF;
and the specific code I'm looking to simplify to be called multiple times with different parameters...
switch (state)
    case OFF:
        state = DELAYING;
    case DELAYING:
          state = ON;
      else {
        state = OFF;
    case ON:
          // do nothing
          state = OFF;
Something like...
void loop{
     switch(state, co2, co2Slider, co2Relay);
switch(state, int actualValue, setValue, relayValue)
    case OFF:
      if (actualValue < setValue) {
        state = DELAYING;
etc etc etc
But that doesn't seem to work.
Any Thoughts?
A switch/case is a statement not a declared function in your code. It takes only one expression.
Create a new void function that is passed your multiple values, and contains your switch/case statement code.
You will now need different "enum States" of different names and when you pass this variable
to your function it will be by reference. This means putting a "&" in front of the variable to allow
the function to modify it. As you will need the different states to be modified and kept track
of differently.
It looks like you know what to do with your actualValue, setValue, relayValue, but you have to give these
variables in your new function a proper type.
Since you declared the variables that you are using in your main loop as 'int' these all need to be int too.
delayingFromMs can likely remain a global timer for all three, but if you want different timers then they need to be made and passed by reference too.
This is tough.
I'm definitely having troubles with the reference variable and the enum... I'm kind of guessing here... Doesn't seem like a very beginner topic from my searching :confused:
But here's what I have... definitely doesn't work, but am I on the right track?
#include <Bridge.h>
#include <Wire.h>
SimpleTimer timer;
HTU21D myClimate;
int tempRelay = 10;
int humdSlider = 30;
int humdRelay =  5;
float t;
float h;
enum State {
  OFF = 0,
  DELAYING = 1,
  ON = 2
} state;
enum tempState {
  tempOFF = 0,
  tempDELAYING = 1,
  tempON = 2
} tempstate;
enum humdState {
  humdOFF = 0,
  humdDELAYING = 1,
  humdON = 2
} humdstate;
unsigned long delayingFromMsTemp;
unsigned long delayingFromMsHumd;
char auth[] = "????";
  Blynk.begin(auth);
  state = OFF;
  tempstate = tempOFF;
  humdstate = humdOFF;
  pinMode(humdRelay, OUTPUT);
  myClimate.begin();
// Temperature display in Blynk
BLYNK_READ(0) {
  Blynk.virtualWrite(0,t);
BLYNK_WRITE(2) {
//Humidity display in Blynk
BLYNK_READ(0) {
  float h = myClimate.readHumidity();
  Blynk.virtualWrite(1,h);
//Humidity Setting in Blynk on Virtual Pin 2
BLYNK_WRITE(2) {
  humdSlider = param.asInt();
  Blynk.run();
  derp(&tempstate, t, tempSlider, tempRelay, delayingFromMsTemp);
  derp(&humdstate, h, humdSlider, humdRelay, delayingFromMsHumd);
void derp(int &state, int actualValue, int setValue, int relayValue, int delayingFromMs) {
  switch(state)
    case OFF:
        state = DELAYING;
    case DELAYING:
          digitalWrite(relayValue, HIGH);
          state = ON;
      else {
        state = OFF;
    case ON:
          // do nothing
          digitalWrite(relayValue, LOW);
          state = OFF;
Note that if you are sticking with using enum there is a bit of a hack you need to do to pass
the variables to your functions.
See the FAQ on this page. This work around is easy.
When you pass it to your function you don't declare it as an 'int', but what you called it. in this case 'State'.
For it not to be confusing don't call your State variables things like state. That will only mess with your head and any one trying to help you.
And the enum variable that is used in your function, in this case 'derp', does not need to be called state. It can be called something else to help you understand that your function is working on this variable.
EDIT: You don't need to make more enum structures. Just declare new variables.
enum sensorState {
  OFF,
  DELAYING,
  ON
sensorState temperatureSensor = OFF;
sensorState CO2Sensor = OFF;
sensorState carbonSensor = OFF;
//or whatever, etc.
When you call a function you don't need to put the & symbol in front of the variable you are passing to it. Only when defining the function parameter need it.
If your timers are unsigned longs, the function needs to be passed unsigned longs as well, not ints.
I'm having a really tough time wrapping my head around this....
Let's start with the EASY >:( hack :slight_smile:
So I'm creating a separate state.h file... and in that file....
I'm putting:
enum sensorState {
OFF,
DELAYING,
ON
tab.h
enum sensorState {
  OFF,
  DELAYING,
  ON
sensorState var1 = OFF;
sensorState var2 = OFF;
sensorState var3 = OFF;
//Call em whatever
Main Sketch
#include "tab.h"
  doSomething(var1, 30);//Hey! I am doing something with my temp sensor state. I hope it does something useful
void doSomething(sensorState &mystate, int someVariable) {
  switch (mystate)
  case OFF:
Cool. I'm awfully close, but I'm having some issues with adding my library... It doesn't seem to want to compile- it seems to have to do with adding in that .h file... Should I be adding this into the libraries folder in the same way as most libraries (and it's just my .h file, yes?) or can i put it next to the .ino in the sketch folder? Either way actually hasn't seemed to work.
#include "relay.h"
#include <Bridge.h>
#include <Wire.h>
SimpleTimer timer;
HTU21D myClimate;
int tempRelay = 10;
int humdRelay =  5;
float t;
float h;
char auth[] = "b828e244f8b94392af33e13c346a4244";
  Blynk.begin(auth);
  myClimate.begin();
BLYNK_WRITE(2) {
BLYNK_READ(0) {
  Blynk.virtualWrite(1, h);
BLYNK_WRITE(2) {
  Blynk.run();
  derp(tempState, t, tempSlider, tempRelay, delayingFromMsTemp);
  derp(humdState, h, humdSlider, humdRelay, delayingFromMsHumd);
void derp(sensorState &myState, int actualValue, int setValue, int relayValue, unsigned long delayingFromMs) {
  switch (myState)
    case OFF:
        myState = DELAYING;
    case DELAYING:
          myState = ON;
      else {
        myState = OFF;
    case ON:
          // do nothing
          myState = OFF;
And my relay.h file:
enum sensorState {
  OFF,
  DELAYING,
  ON
sensorState tempState = OFF;
sensorState humdState = OFF;
sensorState co2State = OFF;
Are you adding a tab by using the in-IDE option?
It should just drop the .h file directly into the correct sketch folder when done like this.
Yep, I used the tab in the ide and made the 'relay.h' file and saved the entire thing as a sketch folder as usual.
This is my error message, but I'm having zero problems with Blynk libraries in any of my other (also, more Blynk-heavy) sketches.
Arduino: 1.6.4 (Linux), Board: "Arduino Yún"
Build options changed, rebuilding all
Using library relay in folder: /home/zee/Arduino/libraries/relay (legacy)
Using library Bridge in folder: /home/zee/Arduino/libraries/Bridge
Using library Blynk in folder: /home/zee/Arduino/libraries/blynk-library-0.3.0
Using library Wire in folder: /home/zee/Desktop/arduino-1.6.4/hardware/arduino/avr/libraries/Wire
Using library SparkFun HTU21D Humidity and Termperature Sensor Breakout in folder: /home/zee/Arduino/libraries/SparkFun_HTU21D_Breakout_Arduino_Library-master
Using library kSeries in folder: /home/zee/Arduino/libraries/kSeries (legacy)
Using library SimpleTimer in folder: /home/zee/Arduino/libraries/SimpleTimer (legacy)
/home/zee/Desktop/arduino-1.6.4/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Yun" -I/home/zee/Desktop/arduino-1.6.4/hardware/arduino/avr/cores/arduino -I/home/zee/Desktop/arduino-1.6.4/hardware/arduino/avr/variants/yun -I/home/zee/Arduino/libraries/relay -I/home/zee/Arduino/libraries/Bridge/src -I/home/zee/Arduino/libraries/blynk-library-0.3.0 -I/home/zee/Desktop/arduino-1.6.4/hardware/arduino/avr/libraries/Wire -I/home/zee/Arduino/libraries/SparkFun_HTU21D_Breakout_Arduino_Library-master/src -I/home/zee/Arduino/libraries/kSeries -I/home/zee/Arduino/libraries/SimpleTimer /tmp/build1370233910885866603.tmp/sketch_nov04x.cpp -o /tmp/build1370233910885866603.tmp/sketch_nov04x.cpp.o
In file included from /home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkApi.h:17:0,
                 from /home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkProtocol.h:18,
                 from /home/zee/Arduino/libraries/blynk-library-0.3.0/BlynkSimpleYun.h:18,
                 from sketch_nov04x.ino:3:
sketch_nov04x.ino: In function 'void BlynkWidgetRead0(BlynkReq&)':
/home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkHandlers.h:64:10: error: redefinition of 'void BlynkWidgetRead0(BlynkReq&)'
     void BlynkWidgetRead ## pin  (BlynkReq& request)
/home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkHandlers.h:70:31: note: in expansion of macro 'BLYNK_READ_2'
 #define BLYNK_READ(pin)       BLYNK_READ_2(pin)
sketch_nov04x.ino:49:1: note: in expansion of macro 'BLYNK_READ'
/home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkHandlers.h:64:10: error: 'void BlynkWidgetRead0(BlynkReq&)' previously defined here
sketch_nov04x.ino:37:1: note: in expansion of macro 'BLYNK_READ'
sketch_nov04x.ino: In function 'void BlynkWidgetWrite2(BlynkReq&, const BlynkParam&)':
/home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkHandlers.h:61:10: error: redefinition of 'void BlynkWidgetWrite2(BlynkReq&, const BlynkParam&)'
     void BlynkWidgetWrite ## pin (BlynkReq& request, const BlynkParam& param)
/home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkHandlers.h:69:31: note: in expansion of macro 'BLYNK_WRITE_2'
 #define BLYNK_WRITE(pin)      BLYNK_WRITE_2(pin)
sketch_nov04x.ino:55:1: note: in expansion of macro 'BLYNK_WRITE'
/home/zee/Arduino/libraries/blynk-library-0.3.0/Blynk/BlynkHandlers.h:61:10: error: 'void BlynkWidgetWrite2(BlynkReq&, const BlynkParam&)' previously defined here
sketch_nov04x.ino:44:1: note: in expansion of macro 'BLYNK_WRITE'
Multiple libraries were found for "relay.h"
 Used: /home/zee/Arduino/libraries/relay
 Not used: /home/zee/Desktop/arduino-1.6.4/libraries/relay
Multiple libraries were found for "Bridge.h"
 Used: /home/zee/Arduino/libraries/Bridge
 Not used: /home/zee/Desktop/arduino-1.6.4/libraries/Bridge
Multiple libraries were found for "BlynkSimpleYun.h"
 Used: /home/zee/Arduino/libraries/blynk-library-0.3.0
 Not used: /home/zee/Desktop/arduino-1.6.4/libraries/blynk-library-0.3.0
Multiple libraries were found for "SparkFunHTU21D.h"
 Used: /home/zee/Arduino/libraries/SparkFun_HTU21D_Breakout_Arduino_Library-master
 Not used: /home/zee/Desktop/arduino-1.6.4/libraries/SparkFun_HTU21D_Breakout_Arduino_Library-master
Multiple libraries were found for "kSeries.h"
 Used: /home/zee/Arduino/libraries/kSeries
 Not used: /home/zee/Desktop/arduino-1.6.4/libraries/kSeries
Multiple libraries were found for "SimpleTimer.h"
 Used: /home/zee/Arduino/libraries/SimpleTimer
 Not used: /home/zee/Desktop/arduino-1.6.4/libraries/SimpleTimer
Error compiling.
