You missed a colon out of the address
Try this.
#include "blinker.h"
// So everyone wants newbies to write blink without delay. This is good
// because delay() is bad. Well, here's the simple way to do it..
#define pumpPin 13 // Change this to suit your needs.
#define pumpTime 5.0 * 60.0 * 1000.0 // 5 minutes * 60 sec * 1000 ms -> time in Ms
#define soakTime 2.0 * 60.0 * 60.0 * 1000.0 // 2 hours * 60 min * 60 sec * 1000 ms -> time in Ms
// Allocate a global blinker object.
blinker aBLinker(pumpPin,pumpTime,soakTime + pumpTime);
// Fire it up.
aBLinker.setOnOff(true);
// blinker is an idler. Calling idle() once in loop lets ALL idlers run.
idle();
You'll need LC_baseTools from the IDE library manager to make this compile.
-jim lee
Frustration level high. I have poured over the code to no end. I scrapped everything and started a new. The relay comes on but nothing else. Again, I need this to run, without blocking. Intended to have pump run for 4 minutes and off for 4 hours. This code is just set for 1 second. I have written in Serial print to see how far the code runs. I only get to "PUMP STARTING". Can anyone help me?
const int relayPin = 8;
const int relayInterval = 1000;
const int waterDuration = 1000;
byte relayState = LOW;
unsigned long currentMillis = 0;
unsigned long millis();
unsigned long previousRelayMillis = 0;
Serial.println("PUMP STARTING");
pinMode(relayPin, OUTPUT);
currentMillis = millis();
void relay() {
if (relay == HIGH) {
if (currentMillis - previousRelayMillis >= waterDuration) {
relayState = LOW;
Serial.print("WATERING");
previousRelayMillis += relayInterval;
else {
relayState = HIGH;
Serial.print("PUMP OFF");
previousRelayMillis += waterDuration;
The FSM in this post seems made to order.
Here is the complete code example of the unequal blink without delay referred to in #1 and #4. The interval switches between the on and off times. Revise as you need.
const byte ledPin = LED_BUILTIN;// the number of the LED pin
byte ledState = LOW;
unsigned long previousMillis = 0;
unsigned long intervalOn = 4*60*1000; //Four minutes on
unsigned long intervalOff= 4*60*60*1000; //Four hours off
unsigned long interval = intervalOff; //start with pump off
pinMode(ledPin, OUTPUT);
if (currentMillis - previousMillis >= interval) {
if (ledState == LOW) {
ledState = HIGH;
interval = intervalOn;
ledState = LOW;
digitalWrite(ledPin, ledState);
Thank you everyone for your input and advice. What a great community. My hats off to the folks that offered up the blink method. Wow, it looks so simple I didn't think it would work. But it works flawlessly and is very adaptable. Cheers
I am glad that you finally took note and that it works for you
Good luck with your project
