using Arduino Mega with two LEDs and two push buttons, each button turns on another led (BTN1_PIN, BTN2_PIN, LED1, LED2)
I want when button1 is pushed the ledPin1 to turn HIGH and the same for button2 and ledPin2
but it should include this:
When button1 is pressed a 7-second timer starts, during those 7 seconds if button2 is pushed it won't work. Once the 7 seconds are up pushing button2 turns on ledPin2 again.
Last part: If button1 is pushed and starts the 7 seconds timer...if at any point button1 is pushed again- the timer restarts and pauses button2 for 7 seconds
I have written the following
#include <InputDebounce.h>
#define LED1 11
#define LED2 12
#define BTN1_PIN 53
#define BTN2_PIN 22
const unsigned long eventInterval = 7000;
bool btn1Flag = false;
unsigned long previousTime = 0;
int button1State = 0; // variable for reading the pushbutton status
int button2State = 0; // variable for reading the pushbutton status
int lastButton1State; // the previous state of button
int currentButton1State; // the current state of button
int led1State = LOW; // the current state of LED
int lastButton2State; // the previous state of button
int currentButton2State; // the current state of button
int led2State = LOW; // the current state of LED
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(BTN1_PIN, INPUT);
pinMode(BTN2_PIN, INPUT);
currentButton1State = digitalRead(BTN1_PIN);
currentButton2State = digitalRead(BTN2_PIN);
/* Updates frequently */
unsigned long currentTime = millis();
lastButton1State = currentButton1State; // save the last state
currentButton1State = digitalRead(BTN1_PIN); // read new state
lastButton2State = currentButton2State; // save the last state
currentButton2State = digitalRead(BTN2_PIN); // read new state
if (lastButton1State == HIGH && currentButton1State == LOW)
led1State = !led1State;
digitalWrite(LED1, led1State);
//iteratin: 1 (if 100ms - 0 <= 3000 will give me true
if (currentTime - previousTime >= eventInterval) {
//set the btnFlat with fale
previousTime = currentTime;
//if the user presses the button1 at any moment
if (currentButton1State == HIGH)
//I will reset my interval time. by adding the interval time to my current time and assign it to my NEW eventInterval time again
btn1Flag = true;
if ((lastButton2State == HIGH && currentButton2State == LOW) && btn1Flag)
led2State = !led2State;
digitalWrite(LED2, led2State);
but it doesn't seem to work. I don't know where to start. any help would be appreciated
Thanks
You should only save lastButton?State when currentButton?State changes, so you need to move those assignments into the "if" block. Also, the if (currentButton1State == HIGH) statement will never be reached, so that may be removed from the code.
bool timerStarted = false;
timerStarted = true;
if (timerStarted && (currentTime - previousTime >= eventInterval)) {
btn1Flag = true;
use a button library to make your code easier to develop (Once you get that working you could implement your own button handling if you want to get rid of the library)
this has the advantage of offering a programming API that is close to your specifications
can you clarify what "pushed" mean ? Is that "as long as the button is down" or more like a click on the push button ?
what happens if button2 is already held down when you press button1: does the 7 second timer kicks in anyway in case you release button2?
#include <Button.h>
#define LED1 12
#define LED2 11
#define BTN1_PIN 53
#define BTN2_PIN 22
Button button1(BTN1_PIN);
Button button2(BTN2_PIN);
button1.begin();
button2.begin();
currentButton1State = button1.read(); // read button1 new state
currentButton2State = button2.read(); // read button2 new state
if (button1.released())
btn1Flag = true;
if (button2.released() && btn1Flag)
Fix ver0.3
I have added the button library. Thank you it's clearer now. it is still missing something. because the code works for the first 7 seconds only. then it behaves normally
I have two logic errors now
I must press button 1 on the first run (which is not the case - because I want to let the user press button 1 or button 2 at any moment).
If the user pressed Button 1. It supposes to block Button 2 Input for 7 seconds. If the user during those 7 seconds press Button 1 again (changed button 1 state). it is supposed to reset the 7 seconds timer.
