I've been looking for a tutorial for this task for many hours. Alas, I have found nothing.
So I bring forth the problem to this forum in the hopes that a kind soul can at least guide me in the right direction.
My task is simple. I would like to move a servo on the one hand, and display bitmaps on an OLED on the other. I have the servo functioning with millis. However, I cannot for the life of me work out how to display the bitmaps.
I have converted all the bitmaps into code form via LCD Assistant. I am using the "Adafruit SSD1306"
and "Adafruit GFX" libraries.
The command to draw a bitmap is "display.drawBitmap( x, y, 'name', w, h, 'colour')".
The problem is that the tutorials for millis usually relate to a variable within the brackets. I can't draw a bitmap the same way I can write an LED or a servo. So I'm left rather confused.
The question I am left with is this: What is the simplest way to draw bitmaps with millis?
BurrBoy:
That does not make any sense. Why would you expect to draw a bitmap in the same way that you write to a servo? That's a bit like expecting to bake a cake the same way you ride a bicycle.
Post our program so we can better understand your problem.
