I am trying to add a timestamp that when the loop iterates it adds the timestamp by using mills()
Here is my code: (any help that you can give me would be very much appreciated)
Also I know that under the void loop I have the millis() function randomly written, I am just unsure how to add it into the program
#include <SPI.h>
#include <SD.h>
const int chipSelect = 53;
int timej = 0;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 3) {
dataString += ","; millis()
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
Why not just write the data to the file as binary?
Much faster.
You have the (incorrect) call to millis() in the for loop - do you need a stamp for every reading?
They're only going to be about 100us apart, so there's a good chance they'll all have the same millis() value anyway.
Yes the professor wants us to have a timestamp for every reading to write the proper code to read all three analog signals from the accelerometer and save the data in the SD card via the SD Card reader provided.
The problem is I have no clue how to add the timestamp to the readings when the loop iterates. what would be the code to do this, is what im looking for.
Yes. Correct it is the same person, I could not figure out my old login/email so I made a new account. I apologize for reposting this question/thread multiple times, it will not happen again, I have secured a new account now.
Thank you for the help, I still have no clue what do though because I don't understand the code as it was just adapted from the tutorials from Arduino.
Thank you very much. I kinda understand what you were saying when you said the following:
"So, you know how to turn an analogue reading in a variable (an integer value) into part of a String. All you have to do is put the value of millis() into a variable, and append it to your String."
but I do not know how to implement that in the code / what the problem is.
