Can i use mini 360 stepdown voltage to power Infrared LED 5 mm, 940mn. I will use 5 pcs on parallel. The supply voltage for mini 360 is 5v from smartphone charger and i will set on required voltage needed of ir led.
I will use it for my ESP32-CAM no ir filter already for nightvision
Here the actual photo of the item.
- Module property: Non-isolation buck
- Rectification mode: Non-synchronous rectifier
- Input voltage: 3.6 V - 46 V
- Output voltage: 1.25 V - 35 V
- Output current: Rated current is 3 A,
- Conversion efficiency: 92% (highest)
- Switching frequency: 65 kHz
- Output ripple: 30 mV (maximum)
- Load regulation: ±0.5%
- Voltage regulation: ±2.5%
- Work temperature: -40° - 85°
- Dominant Wavelength: 940 nm
- Emitted Color: Infrared receiving
- Forward Voltage (V) : 1.27 - 1.4 V
- Reverse Current: 10 μA
