Using MOSFETs with Arduino nano
This just makes no sense at all.
I think you don't actually have things connected as you've described, or you have the mosfet pinout wrong, or it's not the mosfet you identified. I don't know where to go from here. But let me ask again, what is the voltage on the three mosfet pins when D2 is high and the mosfet is supposed to be on (no diode)?
// C++ code
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
delay(5000); // Wait for 5000 millisecond(s)
digitalWrite(2, LOW);
That is the test code we are using while we try and figure it out... It's just a easy on off on pin 2 for output. I'm sorry I can't offer you what you need asap as I said before I'm trying to help my 13 year old son. I have no understanding of Arduino stuff... Although I do have a ton of 12v DC knowledge from being an automotive electrical tech and accessories installer. But we never got into hooking up MOSFETs... Like I said before I appreciate anyone's input and apologize for the missing info, I'm trying my best to get all this while life is happening.
When there is no diode or resistor in-between gate and source, it looks like this: gate- 5v drain- 8-9v source - ground.
When the 10k resistor is in-between the gate and source, it looks like this: gate - .4v drain - nothing source - ground
The original diagram with the lamp had the resistor as a pulldown to ground from the D2-to-gate connection, not inline between them as you apparently have it. The pulldown version is the correct one. It's there only to make sure the mosfet stays off when it's supposed to be off.
But we still have the situation where the gate-source voltage is 5V, but the mosfet is off. That shouldn't be possible. Can you double check the mosfet part number, and the pinout as shown in its datasheet?
BOJACK RFP30N06LE MOSFET 30 A 60 V RFP30N06LE N-Channel Power MOSFET Transistor ESD Rated TO-220 (Pack of 10 Pcs) https://a.co/d/bKdp6C9
Those are the MOSFETs we ordered, being that they are Amazon they could be wrong? Or bad, but we've tried all 10. Thank you for helping... I appreciate it!
Nick
What is "nothing"?
Do you have a multimeter with diode test feature?
Follow this video
Also, with it turned on (conduction between drain and source) move black lead from source to gate. It should be open (OL)
There is no reason your gate should be 0.4V when D2 is High. Can D2 still drive an LED? LED on when D2 is High
