Hello Everyone, I am currently working on a project for my college assignment. I aim to make a head-mounted device with MPU6050 to detect wether the user is nodding or shaking their head. I am currently porting my data into Unreal Engine using the Serial Port Communication Plugin since part of my project will require the Unreal Engine. I currently run the calculations of nodding and shaking in Unreal but I feel like maybe I should do it in arduino. Anyways, I am very new to Aduino, so I have no clue what I should do. I researched Kalman filter but only got confused. Can anyone please tell me how to make it stable and actually detects the head movement correctly? I am not looking for precision just detecting two movements correctly. Thank you for taking time to read my problems.
Here is my current code:
//A god-forsaken code
#include <Kalman.h>
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
MPU6050 mpu;//declare mpu6050
Kalman kalmanX, kalmanY, kalmanZ; //declae kalman filter
int16_t ax, ay, az;//accelerometer value
int16_t gx, gy, gz;//gyroscope value
float filX, filY, filZ;//filtered value
uint32_t timer;
Wire.begin();
mpu.initialize();
kalmanX.setAngle(0);//Set Kalman filter value to 0
kalmanY.setAngle(0);
kalmanZ.setAngle(0);
timer = micros();//Set timer
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);//Get mpu6050 value
//calculate the time between data
double dt = (double)(micros() - timer) / 1000000;
timer = micros();
filX = kalmanX.getAngle(ax, gx, dt);//Input the accelerometer data(ax)and gyroscope data(gx)and time(dt)To the kalman fiter program
filY = kalmanZ.getAngle(ay, gy, dt);
filZ = kalmanZ.getAngle(az, gz, dt);
byte mappedX = map(filX, -17000, 17000, 0, 255);//map the filtered data to 0-255 for easier transfer
byte mappedY = map(filY, -17000, 17000, 0, 255);
byte mappedZ = map(filZ, -17000, 17000, 0, 255);
//data transfer
Serial.write(mappedX);
Serial.write(mappedY);
Serial.write(mappedZ);
//Serial.println(mappedX);
//Serial.println(mappedY);
//Serial.println(mappedZ);
delay(50);
Don't bother with the Kalman filter, it doesn't do anything useful.
You need to understand what the gyro actually measures, which is rate of rotation about three axes, not angles.
The rates of rotation alone are probably all you need to detect head nodding or shaking.
I suggest to just hold the sensor in your hand, while printing of the raw gyro measurements, and study the effect of rotating the sensor about different axes, at different rates.
This very simple code should get you started:
// MPU-6050 Short Example Sketch modified for gyro rates only
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
Wire.write(0x43); // starting with register 0x43 (GYRO_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 6); // request a total of 6 registers
int16_t t = Wire.read();
GyX = (t << 8) | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
t = Wire.read();
GyY = (t << 8) | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
t = Wire.read();
GyZ = (t << 8) | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
t = Wire.read();
Serial.print("Gyro: "); Serial.print(GyX);
Serial.print(", "); Serial.print(GyY);
Serial.print(", "); Serial.println(GyZ);
delay(333);
I forgot to mention that the gyro has to be calibrated to remove the offsets, which is another reason the code you posted won't work as you might hope.
Here is a program that averages the first two hundred readings, then subtracts the offsets from the rest of the measurements.
// August 17, 2014
// Public Domain
#include<Wire.h>
int16_t GyX, GyY, GyZ;
Wire.begin();
int count = 0;
long sumx = 0, sumy = 0, sumz = 0;
t = Wire.read();
t = Wire.read();
if (count < 200) { //add up gyro readins for offset calculations
sumx += GyX;
sumy += GyY;
sumz += GyZ;
count++;
else if (count == 200) { //calculate gyro offsets
sumx = sumx / count;
sumy = sumy / count;
sumz = sumz / count;
count++;
Serial.print("Gyro offsets: ");
Serial.print(sumx);
Serial.print(", ");
Serial.print(sumy);
Serial.print(", ");
Serial.println(sumz);
else { //subtract offsets and print results
Serial.print("Gyro: "); Serial.print(GyX-sumx);
Serial.print(", "); Serial.print(GyY-sumy);
Serial.print(", "); Serial.println(GyZ-sumz);
delay(333);
