Using multible pins
Hello, I want to use my RFID-chip and my SD-card. Both are one the same pins: 53 52 51 50. Can I use the pins multible times or do I have to use other pins?
Those are the SPI pins on a Mega. Are you using a Mega?
All devices share 50, 51, 52. Each device must have its own CS pin.
pin 50 is MISO, pin 51 is MOSI, pin 52 is SCK, pin 53 is the default CS. I would use pin 10 as the other CS,
Arduino SPI tutorial.
The SPI pin pins now have different names in some places (PC). Up to you to figure that out.
Yes I use a mega (sorry)
Thank you
You are welcome.
If your question was answered to your satisfaction, please mark the thread as solved so that other members do not waste their time opening the thread wanting to help only to find that the problem no longer exists.
