Using Multiple ADS1X15 on Single ESP32
Hello, I have been using a single ADS1115 on an esp32 with the Adafruit library:
Adafruit_ADS1X15.h
I now need to add a second one as I need to measure 6 things.
I have tried to find how to address multiple ads using the arduino interface and this library, and all have given the solution as:
Adafruit_ADS1115 ads0(0x48);
Adafruit_ADS1115 ads1(0x49);
However I get an error: no matching function for call to 'Adafruit_ADS1115::Adafruit_ADS1115(int)'
It will let me define multiple ads like below:
Adafruit_ADS1115 ads0;
Adafruit_ADS1115 ads1;
and call functions with each like this:
adc0 = ads0.readADC_SingleEnded(0);
adc1 = ads0.readADC_SingleEnded(1);
adc2 = ads0.readADC_SingleEnded(2);
adc3 = ads0.readADC_SingleEnded(3);
results = ads1.readADC_Differential_0_1();
but how would I know or dictate which address each corresponds to?
Each will be doing different things and be wired in with their addresses via a wire to gnd or vdd, so i need to know which ads the function is pointing to.
Any guidance would be appreciated.
can you share a link to the library you used?
seems you can use the begin() method to pass the I2C address
Hi, The library I used is this one: GitHub - adafruit/Adafruit_ADS1X15: Driver for TI's ADS1015: 12-bit Differential or Single-Ended ADC with PGA and Comparator
It was the only one for the ADS1x15 made by adafruit I could find.
But looks like you nailed it, that seems to work using:
ads0.begin(0x49);
ads1.begin(0x48);
Thank you very much for the help!
great ! :wink:
have fun
