using multiple hc-05 bluetooth modules with single arduino mega
:confused: please someone tell me , can i use multiple hc-05 bluetooth modules with arduino mega that comes with 4 Rxd and Txd pin , i am confused that if i connect each bluetooth module with those 4 pins does it will work ? and my requirement is to control same device with multiple smartphones with arduino mega , please if you have any suggestion contact me
Moderators note : It is not a good idea to publish your email address in an open forum because of the risk of spam
EMAIL ADDRESS REMOVED BY MODERATOR
The answer to your question is yes, you can use multiple hc-05 bluetooth modules with an arduino mega as it has 4 hardware serial ports
It is up to the program which port it reads and when and what it does with the data received
