Using multiple I2C devices on the same bus
Hello
I have a BME280 temperature, pressure and humid module and a H5883 magnetometer hooked to the same I2C bus on a Mega2560. The BME280 works good. The H5883 works. Bit they won't work together. Separate sketches will work each module. I'm trying to combine them for a weather station. When I do, the BME280 works, but the H5883 will not. -1 for each of the three axis. The wiring is the same for both. I haven't touched it, just the sketches. It has to be an addressing issue in the sketch. How can I get it to talk to both? I want to add more modules later. I've included the sketch I'l working with so far. Any help is appreciated.
So far all my searching shows the physical wiring, the bus protocol and talking to one device.
WX_test_program.ino (3.99 KB)
Snaresman:
Hello
Snaresman:
Hello
For starter run this I2C scanner sketch and check what the addresses are for each of you chips.
Then I would check that the addresses match what the datasheets say the default addresses should be.
It may be that the address of the H5883 is manually set to an address other than the default through the hardware a address pin.
In that case you would have to modify the library to use the non-default address of your actual chip.
That is one possibility anyway, and that is where I would start.
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
  Serial.begin (115200);
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 8; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
I2C address for the BME280 is either 0x76 or 0x77 and the HMC5883 compass is at 0x1E, so there is no fundamental reason why they should not work together.
Have you got pull up resistors on the I2C lines to 3V3?
Are these chips you are using or are they boards that contain these chips? If so please post a link to these.
The worry is that the Mega is a 5V device and the chips are 3V3 so do the boards contain signal level translators?
